pfrederi 21,107 #1 Posted May 21, 2017 My weekender neighbor has a C125-8 that decided it wouldn't shift into reverse. the shifter was sloppy so i figured the dog point set screw needed work. Got it in to 3rd and drove it to my place. Nothing wrong with set screw but the roll pin that goes through he donut and shifter had sheared . Got him back mowing with a spare gear shift I had on the shelf. The roll pin is 5/32 and the donut is 1 inch across but you have to leave some room for the dog point. I am thinking 7/8" but does anyone know the length WH used? Second question i have seen some shifters that have a weld on the top of the donut to the shaft. Was that a later factory idea, or a dealer /repair idea. Any reason I should do that in addition to the new roll pin??? 1 Share this post Link to post Share on other sites
stevasaurus 23,828 #2 Posted May 21, 2017 The factory is 13/16" long and a 5/32" roll pin...# 933168. Paul, I believe all the weld on top of those doughnuts was not factory. If the trans shifts OK after you fix it, I would not weld it. 1 Share this post Link to post Share on other sites
WHX?? 57,991 #4 Posted May 22, 2017 (edited) 20 hours ago, stevasaurus said: weld on top of those doughnuts was not factory Is that right Steve? Is that true for all models? If I remember right all the ones I ever dealt with were welded & just assumed it was factory Never noticed there was a roll pin in there, thought the dog point divot was just a drilled hole. Will have to be more observant in that area. Edited May 22, 2017 by WHX11 1 Share this post Link to post Share on other sites
stevasaurus 23,828 #5 Posted May 22, 2017 Jim, there is no way that I can be positive that the welds were factory or not. There may even be a Service Bulletin so it gets done at the dealers. I'm just thinking that why would you weld something that uses a roll pin right from the factory. It makes no sense, since, cents. 2 Share this post Link to post Share on other sites
buckrancher 2,697 #6 Posted May 22, 2017 all the newer tractors were welded Brian 1 Share this post Link to post Share on other sites
