TIGman
Simplicity/Allis Chalmers "faux" grader blade
TIGman
 Finally had a little bit of a break at work so I had time to weld together the "faux" grader blade for my Simplicity/ Allis Chalmers tractors that I started last fall.
 Guess you could say I did some "Reverse Engineering" using some line drawings and photos of a blade and calculation of dimensions.
Edited by TIGman
  • Like 8
KC9KAS
Very nice!
squonk
I did almost the same thing a few years back. Only I made it for both the rear and mid point. Those heavy AC blades work awesome!
TIGman
  I was thinking about making up an adapter for it so I can also use it as a back blade on the :wh: slot hitch. :handgestures-thumbupright:
