TravelinJavelin 620 #1 Posted May 20, 2017 well going over my machine today and well cleaning out the old drive belt crap and debris and noticed the pulley on the tranny was oily and filthy do you think I should take it off to clean or use some brake cleaner and let evaporate? also if I do have to pulley off how does one get it off? Share this post Link to post Share on other sites
oldlineman 1,482 #2 Posted May 20, 2017 (edited) The oil is coming from someware probable the input shaft seal that the pulley is on. That being said, cleaning off the oil will only be a temp. repair. You need to find the source of the oil and fix it, most likely the shaft seal. I believe it should have a set screw and key way in the pulley and shaft. And thank you too all veterans for your service to this great country, and to my 92 year old dad, WW2 veteran Army combat medic, thank you Dad. Bob Edited May 20, 2017 by oldlineman 2 Share this post Link to post Share on other sites
TravelinJavelin 620 #3 Posted May 20, 2017 ok I will try to find it on there and thank you Share this post Link to post Share on other sites
