Similar Content
By HumbleHans
Operator manual 810343R1
Wiring
34 pages 17.5MB
Wiring Colored
1 page 228KB
By RussAMC
New to the forum, in fact never joined a forum of any kind before, so my apologies if I'm clumsy at this. I have aquired a 312-8 with a 2 blade deck and bagger. I believe it is a 37" but has been patched and painted and no longer has a id tag. I read previous posts on your forum stating that the mule drive with 1flat + 1 v pulley ( which is what I have ) required a v belt. Tractor had 6 sided belt that was pretty well shot and broke almost immediately. All pulleys on deck are v. Do I have the wrong mule drive ? Bought a v belt for it but seems like the idlers on the deck should be flat. Any help would be greatly appreciated thanks.
By casquis
I recently bought a used wheel horse tractor and it came with a tiller. Problem is that I cannot find the instruction manual for how to attach the tiller to the tractor anywhere online. I'm attaching pictures of the tiller so if any of you guys could help me out I'd really appreciate it.
By deere173
Hello again. I'm helping a friend with a problem with his 312-H tractor and 42 inch rear discharge mower deck. We've done a lot of work on this machine in the last year and the last problem is that the pto belt, or deck drive belt, is wearing out pretty quickly. This will be the second belt this summer. I have tried every belt routing I can see as possible, including reversing the idler pulleys on the forward right side of the tractor frame. We are using belt #108834, 1/2' x 98". Is this normal??
