RJR49
Missing outer spacer
RJR49
I was mowing the yard and when I came around I found the cover to the mule drive laying in the yard. The nut and outer spacer were nowhere to be found. The local hardware store had the nut but, of course, no spacer P/N 101757. Since it has a different P/N than the inner I suspect they are different. If anyone knows what size it is I can make a new one. Otherwise I'll have to guess
gwest_ca
1/2" long spacer part number 101757 is on the outside between the pulley and cover.
5/8" long spacer part number 101734 is between the pulleys.
Spacer ID needs to slip over 3/4" shaft.
Garry
AMC RULES
                  Image result for alien waving gif
