Similar Content
By admin-(Admin)
1 page 187.26KB
Dated January 1966
5409 nylon bushing replaced by 6254 bronze bushing
1966 model 876 - 6254 bronze bushing factory installed after serial 193056
1966 model 1076 - 6254 bronze bushing factory installed after serial 214071
1966 model 1276 - 6254 bronze bushing factory installed after serial 205328
By 1276Beast
I am currently towards the end of a 1276 restoration project, I just got everything back together and sent power to the transmission for the first time. Without the pump on and the gear in neutral, I can spin the axels by hand, one goes one way, the other, the other way, giving me indication that I don't have a differential problem. When I put power to it, everything appears to work as advertised, except when in gear I can stop the Axel from spinning with my hand, little to no resistance. I do have a bit of a rigging problem from worn linkage, but I can move the cam by hand to get it fully in gear. The tow gear in completely closed. Just flushed and filled with fluid. I have not changed the filter.
Any idea on why there seems to be no power in the axels??
By 1slowtbss
I need to get a new engine last season the rod came apart on me well pushing snow in the winter wound up putting a hole in the block it's a 12 hp starter-generator kohler if anyone has one local in the Great Lakes area I will gladly pick it up or have to pay for shipping for any farther away thank you please let me know!!
By admin-(Admin)
1 page 245.91KB
1 page 94.58KB
Dated November 1967
Replaces #085
Tiller 1967 36in model RT-367
1965 model 875
1965 model 1075
1966 model 876
1966 model 1076
1966 model 1276
