Similar Content
By Steelspinner76
Just picked up a wheel horse 606 looks to be pretty complete someone has put a different cover on it and mounted a snow blower style electric start. but everything looks solid and the engine turns over. looking forward to bringing it back. Any things i should look out for on this model
Weak points wear points ect Here is a pic as it is now just arriving home this morning
By Team70R
Well I scored a free 4" linear actuator from a combine so I went ahead a built an electric rear lift. It's not the fastest thing but it definitely beats manually lifting! Right now it's just set up for my grader blade but I will be getting my cultivator and disc to work with it as well. Blade lifts to almost 5"
By Team70R
Thinking about setting up an electric actuator for my rear hitch on my C165. I was wondering if I could put it up under the belly of the tractor and hook the rear cable to it and leave the manual lift handle for the mower deck. Would a 330 pound capacity actuator be enough?
By Bttatro
I have seen these 36" gear driven decks on short frame tractors and lawn rangers alike. And I happen to have one off a lawn ranger, but have a 606 I'd like to put it on. Is this possible? Or do I need some substantial modifications?
Thanks!
By Bttatro
The title pretty much sums it up. I picked up lawn ranger? carcass for $20 in hopes the deck will work on my 606. It looks like they both use the attach-o-mattic, but I could be wrong.
Any help is appreciated. Also if anyone needs parts let me know. It doesn't have an engine, fuel tank, hood, front rims, or probably other things too. (Maybe I should just list what it does have, might be shorter)
Thanks!
