muz123 1,192 #1 Posted May 5, 2017 Just pulled off the seal off of one of the right side of the rear axle. Not sure of the replacement part number as parts tree doesn't show it. Anyone know the seal part number? Thanks, Dave Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,104 #2 Posted May 5, 2017 https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/31-12ke01-312-h-toro-312-h-garden-tractor-1990/transaxle-312-h-416-h/ 6449 is the Toro number Garry 4 Share this post Link to post Share on other sites
pfrederi 17,902 #3 Posted May 5, 2017 or CR11124...excuse me SKF 11124 still Chicago Rawhide for us old farts. 5 Share this post Link to post Share on other sites
ztnoo 2,298 #4 Posted May 5, 2017 http://www.napaonline.com/napa/en/p/NOS11124_0338963144?interchange=1 5 Share this post Link to post Share on other sites
roadapples 6,983 #5 Posted May 6, 2017 Would that be the same for a sunstrand in a 74 C160 automatic? 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,104 #6 Posted May 6, 2017 4 hours ago, roadapples said: Would that be the same for a sunstrand in a 74 C160 automatic? Here is a parts list for the 1974 C-160 uto C-160 should be the same Toro 6449 if it has 1-1/8" diameter axles Toro 100607 if it has 1" diameter axles Garry 2 Share this post Link to post Share on other sites
953 nut 55,883 #7 Posted May 6, 2017 6 hours ago, roadapples said: Would that be the same for a sunstrand in a 74 C160 automatic? That is the seal for any 1 1/8" axle. 3 Share this post Link to post Share on other sites
pfrederi 17,902 #8 Posted May 6, 2017 1 hour ago, 953 nut said: That is the seal for any 1 1/8" axle. Not for gear shift trannies 3 Share this post Link to post Share on other sites
953 nut 55,883 #9 Posted May 6, 2017 3 hours ago, pfrederi said: Not for gear shift trannies Right you are; CR- 11050 for the gear drive transaxle with 1 1/8" axle 2 Share this post Link to post Share on other sites
roadapples 6,983 #10 Posted May 6, 2017 Thanks guys... 2 Share this post Link to post Share on other sites
muz123 1,192 #11 Posted May 7, 2017 Thanks for the help all. Just ordered the one from eBay. 1 Share this post Link to post Share on other sites
