ztnoo
GT 14 Hydraulic Control Valve Problem: Advice Needed
ztnoo
Major,
Yes, I do have the second valve I bought Thursday at Portland (after running over there two consecutive days), but had a couple of other small projects and "to do list" things to attend to before I delve into the valve issue.
I was very fortunate to be able to pick up one so close by. Karl Stohry from Flat Rock, IN (about 2.25 hours drive for me) had one (and a set of hoses and the cylinder to go with it) which I saw on Wheel Horse Garden Tractors and Parts, https://www.facebook.com/groups/WHGTP/
Since Portland is about a 40 minute drive for me, it was a no brainer: Just go get the damn thing..........NOW.
Maybe today and Sunday I can do the analysis and figure out what's going on and how they really function.
As I said in the thread, these valves are simple devices, but without one part in the assembly, they are not going to function properly.
Ultimately I'll figure it out and be able to add to what currently seems to be a very limited fount of information and knowledge about these control valves.
Did you wind up going to Portland on Friday, or did the weather scare you away???
Edited by ztnoo
Molon_Labe
I was going to meet up with GLGRUMPY about a blade for the Yard Man but it was already raining here at 0630 Friday morning, figured it best to have another cup of coffee and watch the news and weather, glad I did. Good to hear that you at least have the parts to get the GT-14 functional again. Maybe one of these days you will come across that lost part for the old valve.
Edited by Molon_Labe
ztnoo
Yeah........I kinda have that spooky feeling that will be the case.
Probably basically a case of user error and not being deliberate enough and observant enough in my disassembly.
Edited by ztnoo
ztnoo
OK folks, I'm back again with some answers.......rather than questions, this time.
Picked up another 8363 valve from another GT 14 at the Portland tractor show last week thanks to Karl Stohry of Flat Rock, IN.
Here's what I found out and it was pretty much what I was thinking all along.............I lost a piece in my initial disassembly of my original 8363 control valve.
I'll more or less let the pics do the talking with captions added where needed.
When the valve lever is in the neutral position (where it always returns after movement either forward or backward), the round head set screw just protrudes from the body of the valve. See white circled area.
When the control; lever is pulled back, the screw and a small metal sleeve attached to the end of the spool, move downward out of the valve body.
5925d763460cb_IMG_1067a.thumb.jpg.1a9d10f3966463b2675069ba2f583206.jpg5925d772af9e2_IMG_1068a.thumb.jpg.156540e11438ed54d9637727ad5ac33d.jpg
Conversely, when the control lever is pushed forward, the spool and the sleeve/screw move upward into the casting body of the valve. The big spring in the side of the valve casting returns the lever and spool to neutral, regardless of the direction it has been moved.
  5925ea923104c_IMG_1071a.thumb.jpg.3091c11a545f742508dcb7dd24ee6a65.jpg5925daca95ca9_IMG_1072a.thumb.jpg.2b25b0100b308ac306220d3b798a2127.jpg
Upon removal of the round head screw, and a slight loosening of the hex allen screw to relieve the ball detent, the metal spacer/sleeve came out of the assembly. As I suspected, this is what I lost previously. Its machined on the upper end to fit into the chamfered end of the spool. The sleeve/spacer has a countersunk area into which the end of the spool fits. It also has a larger diameter shoulder machined into it which serves as a stop for the ball detent in the assembly and prevents the spool from being lower below the ball detent. Note the damaged area on the shoulder of the sleeve/spacer which I believe to be from wear of the detent ball. The last pic in this group shows the flat bottom side of the sleeve spacer which the screw and lock washer rest against on the bottom of the assembly.
5925dd2713bd6_IMG_1073a.jpg.f4dc144881e93245566054431b8c70f8.jpgIMG_1042 a.jpg
So, in the off season, meaning non-mowing season, i.e. winter, I need to find a skilled machinist to duplicate the sleeve/spacer to restore my original control valve to full working order. The job of this part is to limit movement both up and down of the spool. A very simple part basically with a very simple job. But without it, the valve won't fully function.
Next time Steve needs to mind his P's & Q's a little more closely when disassembling something he has never had apart before. Probably a good example of being in a little too much of a hurry. That generally works against not only me, but probably everyone. Lesson learned the hard way......the way you tend to remember more going forward.
Duh.
Edited by ztnoo
  • Like 3
wheelhorseman
Steve I'm glad to hear you figured it out and your back up and running thanks for the good information!
  • Like 3
Aldon
Great information and follow up Steve.
I'll definitely make use of this thread for reference when I rebuild mine.
  • Like 3
ztnoo
Lowell,
Do you have the capability to reproduce a small part like I need?
I guess it would require a small lathe and the skill to operate it, neither of which I have.
Steve
wheelhorseman
 I sure do Steve but I'm busy right now so like you said in the non-mowing season get a hold of me.
ztnoo
Lowell that sounds great!!!
Yeah, definitely it would be late fall or winter, for sure.
I assume you would need the example of the part you are duplicating........for accuracy???
Steve
ztnoo
Many thanks to all who contributed ideas and advice to my hydraulic control valve woes.
You are a great bunch of friends to have!
Kudos!
Regards,
Steve
Molon_Labe
It is so nice to see a thread with closure. All too often the solution to a presented problem, if there is one, is not made known to the forum. Thanks for getting to the bottom of yours Steve and sharing your findings.
wheelhorseman
Steve
Yes or some good measurements of the :thingy: but we can figure that out later. :handgestures-thumbup:
ztnoo
In my hurried quest to discover how to repair a 8363 control valve, how it functioned, and learning the arrangement and disassembly/assembly of parts, as an after thought, I realized I neglected to explain what it took to actually get to the control valve.
As such, I decided an addendum to the thread would be helpful to others, hopefully.
If you are doing a complete restoration of a GT 14, the chore of dealing with an internally mounted part, becomes largely a mute point because of the ease of access you already enjoy. If however you are working on an actively used tractor which you don't have the luxury of dawdling around fixing a severe hydraulic leak in the control valve, your focus becomes "what is the easiest way to go about accessing this part without removing huge numbers of parts for access to the control valve"?
Having been through this dance a few times now, I thought it might be beneficial to describe what I found worked best for me so that others facing similar repairs on their GT 14s could speed up the turn around time removing the valve, installing the new seals, and reinstalling the valve on the tractor. When the grass is growing and you are mowing twice a week, the pressure is on to get the thing repaired because of a very serious hydraulic leak, time is not a luxury you have in abundance.
The first thing you will need to do is remove the knobs on the hydro directional lever and the knob on the control lever. You then can can remove the cover plate and plastic instructional/directional plate. This will gain you access to the valve which lies between the C channel sides, and is attached to the right side channel. The cover plate is shown below with mounting points circled in yellow.
The second part you will have to deal with is the cam plate and idler pulley assembly which is attached to the pivot arm assembly of the mule drive. This apparatus tensions the deck drive belt, but in order to gain access for belt guard removal, you will need to loosen the tensioning nut for the idler pulley enough to allow the drive belt to be pulled to the side once the belt guard mounting bolts have been removed and you are pulling the guard outward. Note the cam plate has been allowed to rotate forward out of the way with the loosening of the belt tensioner.
The guard cannot be removed with the deck drive belt tensioned. The problem area is circled in white below. The second pic show the results of loosening the deck drive belt enough to allow belt guard removal.
592f423ad2fb3_IMG_1088a.jpg.4a0bcef9f7947b1ac5da77e98e949d81.jpg  592f43915409b_IMG_1092a.jpg.0891741dfc29d68195ce802939c055e7.jpg
Next you must remove four 1/2" bolts from the side of the belt guard (circled in white), and a 5/8" bolt from the attachment point on the engine block (circled in yellow).
This allows reasonable access to the 1/2" bolts (circled in white) mounting the control valve to the tractor on the inside of the C channel frame members. You will likely meet some slight resistance to clearing the back of the electric PTO clutch body, but with some wiggling and some light pressure the belt guard can be pulled past the clutch.
592ffa059933f_IMG_1094a.jpg.4662ddabacd5ebefae498b5a3333e4a5.jpg  592ffa1483626_IMG_1095a.jpg.867105d1d24cdbbd879ad4cb93825e99.jpg
At this point, you have gained enough interior (between the C channels) and exterior space (with the belt guard pulled outward) to begin removing the hydraulic hoses from the control valve casting body. I began my loosening the top hose first with a 5/8" wrench, then the left hose (as viewed from the rear of the tractor), thirdly the right hand hose, and lastly the bottom hose. The hoses should be removed from the valve first before removing the mounting bolts which run through the right angle mount. Doing so allows you to gain leverage to loosen the hose connections.......otherwise you'll likely encounter a real knuckle busting session. After the hoses are removed, you can then loosen the mounting bolts running through the right angle mount, and remove the control valve from the tractor for seal servicing.
One of the things I had the most difficulty accessing where the nuts on the right angle mounting plate. I really fought those the first time I removed my original control valve. Both sets of nuts interfered with either the removal of the bracket from the C channel, or removal of the valve from the right angle mounting bracket. After removing the control valve and observing the situation more closely, I determined the bolt heads were about half the height of the nuts which mount the valve to the right angle bracket. By reversing that arrangement and placing the thinner headed bolts on the inside of the right angle bracket and the locking nut on the back side securing the valve casting, I was able to gain enough clearance to make installing the mounting bolts and nuts on the other side of the right angle bracket to the tractor much, much easier. The original set up of the bolts are in the pics below circled in white and yellow. Reversing this arrangement will save a lot of frustration.......guaranteed.
592ffe87374b6_IMG_1034a.jpg.91000be2384852065fefb961b65bef05.jpg592ffe949cab5_IMG_1043a.jpg.f7eb0656bd69dbbdb086063bf3097e4b.jpg
Lastly, I realized I never showed a complete pic of the spool with the new seals installed. Note the direction of the lip (the largest diameter area) of the seal face inward toward each other and the center of the spool.
Hope all this is helpful to someone out there with a similar problem with a control valve on a GT 14.
Steve
Edited by ztnoo
  • Similar Content
    • ztnoo
      By ztnoo
      I've been looking for a replacement small General Motors pickup from roughly 25 years ago in reasonable shape for 4-5 months.
      After reviewing untold numbers of CL listings during the period, I ran across what looked to be a reasonable mileage example in good aesthetic shape within a reasonable driving distance from my location.
      It was listed on CL in Louisville. Not exactly the next county over (a three hour one way drive), but a good enough prospect, I decided to take a day road trip
      3hr 2min, 187 miles, per Mapquest.
      I was thinking.......OK Steve, you are wanting to drive to Louisville to look at a vehicle, so what if I couldn't find anyone (a local friend/neighbor) available on Saturday to go with me?
      Three strikes and I was out. Bingo. Reality sets in.
      My theory was, if it was something I really decided I wanted, I needed to get it out of Louisville THAT day. But with no drafted co-driver, I had a definite problem.
      In a eureka moment, I remembered Chaplain Manny, who I had never met, but with whom I have conversed extensively, not only here at RS, but on various WH FB sites, and by email as well.
      Manny was raised in Louisville, so I instinctively knew he would be an excellent guide and pathfinder in a metropolis I had no familiarity with, other than passing through on I-65 to go to Florida.
      So, I messaged Manny on Friday with my situation and proposal and asked if he would be available to assist me for a few hours on Saturday. He now lives east of Jeffersonville (across the river from Louisville, in Indiana) in a very small rural town.
      He replied and told me he was available to help me, given his wife and young son were away at a wedding he wasn't attending.
      I explained the situation generally, and to my amazement and luck, Manny agreed to help me go into Louisville on my long bed S-15 quest.
      I arrived a little after 9 am at Manny's residence (following a three hour drive) and Manny proceeded to guide me into the bowels of Louisville.
      Traffic was horrific for some reason on Saturday morning on both southbound bridges over the Ohio River into downtown Louisville. Manny speculated there had to be some big event going on downtown that morning, but we never did learn what it might be. I would have definitely lost my cool sitting and waiting for traffic to start moving and the stress of trying to navigate the unfamiliar interior of a major urban jungle. But Manny took it all in stride and we eventually maneuvered around the bottlenecks and we got to the desired address in an area of town known as Germantown.
      So the short of it is, I bought the truck because it was in excellent shape for a 1990 model with reasonable mileage given its age, and Manny drove the station wagon while I followed in the S15 and we went back north across across the bridge over the Ohio River leading the way back to his place east of Jeffersonville. Generally speaking, the theory "move your feet, lose your seat" applies to CL items, because they can move very quickly and you usually have to have your ducks lined up and be ready to act promptly, or there's a high risk of losing your chance. With Manny's help and assistance, I was able to achieve my goal.
      Manny let me park the truck at his house until I can draft a friend into a day road trip to go retrieve my little S15 jewel later this week. When we got back to his place and he showed me his Wheel Horse collection and ongoing projects and we philosophized about life a bit before I left.
      Manny is a great caring and helpful person with a warm and outgoing soul. He has considerable health issues for a male of 56 years of age, but he does his best not to allow that to distract his quality of life and daily routine. I now consider him to be a friend and buddy and not just a correspondent........having met through our mutual interest in Wheel Horses, GT 14s in particular.
      Steve
      ___________________________
      Manny & me.
      Manny in front of my purchase.
      My "new" S15.
    • ztnoo
      By ztnoo
      I've discovered the main engine pulley driving the hydro pump seems to be a bit loose.
      I need to pull the clutch and associated pulleys off to have a look at what's going on back there.
      May be just a loosened allen screw mounting the pulley, a bad key, a bad pulley bore, or some combination of all three.
      Is the clutch mounting bolt going into the crankshaft a right hand thread, or a left hand thread?
      Anyone have a quick answer?
      Steve
    • ztnoo
      By ztnoo
      I have a Kohler K341 on a GT 14 tractor.
      Its always had the typical .....what are they called?........pepper shaker muffler? on the tractor.
      I've had to replace them several times....they seem to just eventually burn up.
      I can honestly say even from day one whenever I installed a new muffler of this type, I really couldn't tell that it really muffled much noise, maybe a little, but very little.
      As usage time goes on, they all got nothing but louder.
      Of course, part of this is the sheer displacement of the motor......35.9 cu. in. = 588 cc. Think of it in terms of a slightly bored out Norton Manx 500 cc thumper with an open megaphone exhaust. Deafening! You don't want to be standing 8 or 10' behind a Manx when it being warmed up and the throttle is being "blipped" to do that, without ear protection.
      These older flat head engines seem to be much louder than the newer OHV engines which are common in lots of equipment now.
      I've owned and used this tractor for 35 years now, and I guess I'm beginning to become somewhat of a crotchety old senior, but its becoming annoying to me (the operator), and I in fact had one neighbor that ragged me out over the noise.
      It may be because they have a pool and spend a fair amount of time outside, and the pool is about 10-11 feet from a chain link fence that divides the properties.
      I'm really not that worried about the neighbor nearly as much as I am myself, or should I say my hearing.
      I already have hearing loss from years of firing pneumatic nail guns and listening to compressors and heavy machinery running on job sites.
      What are you other K341 owners using and doing to get more muffling accomplished?
      Surely there has to be a more reasonable solution which will allow you to hear yourself think after an hour or hour and a half of operation.
      Is there a viable, positive solution for this problem so my ears and head don't ring for an hour after just mowing my lawn?
      Regards,
      Steve
    • ztnoo
      By ztnoo
      As many of you know, I've been in a prolonged battle with the rear hubs, woodruff keys, and oil seals on my 1969 GT 14, Model # 1-7441.
      I'm to the point of installing the new SKF oil seals today as soon as I can round up one more PVC fitting to properly size it to my seals for tap in installation.
      After that, its spin on the new NAPA 1410 hydraulic filter, and then fill with ATF.
      When I drained the tranny, I measured and computed the volume of ATF taken.
      It was right at 128 oz. + or - maybe two ounces. The volume spec says 4 qts. (4 qts. = 1 gallon = 128 oz.)
      So I know I was within spec, and wasn't losing large amounts of fluid, although I have a couple of random minor seepage locations on the tractor.......mostly around the control value which raises and lowers the mower deck.
      ATF is always what has been in the tranny, so that's what's going back in.
      My reason for caution regarding what to use specifically is probably more a matter of jargon and my understanding of terminology than anything.
      Of course, since my GT 14 was a first model year tractor, Type A transmission fluid was specified in all the literature.
      Type A is no longer available, but it my understanding is that equates with Dextron II.
      But isn't Dextron II now an outdated designation?
      If so, what should I be putting back into this Sundstrand  90-2062 tranny to ensure continued adequate trouble-free lubrication???
      I have more than a little angst over wanting to make sure I used the right product in this transmission.
      The changes in products over the years makes it very confusing for those of us who only occasionally wander in and out of discussions like this and automotive/mechanical related jargon and word usage generally.
      So gentlemen, what are your specific recommendations on tranny fluid to use in my Sundstrand, and is there any particular brand any of you favor over another?
      Or is it pretty much the case that ATF is ATF is ATF, the world around?
      Looking forward to your suggestions and recommendations.
      Regards,
      Steve
    • ztnoo
      By ztnoo
      I thought hub removal was taxing stuff, but its almost kid's play when compared to getting a frozen woodruff key removed from an axle still in a tractor.
      After several days of attempting to remove the stuck woodruff key from one of my GT 14 axles by use of about every means known to me and maybe the whole of mankind, I've opted to attempt splitting the key in place in the axle.
      I'm using a Dremel tool with a thin metal cutting disc and working at collapsing the remnants inward then punching the remains out of the key slot.
      I'll get it done one way or another, but I'm going to have to source a new key and I'm thinking why not just replace both axle keys on the tractor.
      The other one almost fell out upon hub removal, so I am being punished unmercifully on this second axle for unknown reasons.
      My preference is to buy replacement parts locally when I can, but with these whopper woodruff keys I seem to be having some difficultly locating the proper replacements nearby.
      They are rather large keys by my standards and brief experience dealing with this stuff.
      I've miked the good key from the second hub removed: 1/4" (W) x .58" (H)  x  2" (L)  on a 2 3/4" diameter, full radius.
      Where and from whom are small volumes (2-10) of woodruff keys of this and similar specifications available?
      Who do you gentlemen recommend and order from?
      Steve
