armstrrw
Drive Belt Pulley
armstrrw
I own a 314-8 Model 73400, Serial 4901829 that I began to disassemble in 2015 due to too much wobble/slop in the drive belt path. It appeared that the main culprits were the clutch cylinder and the idler pulley. After the drive belt broke I pulled it into my shop and disassembled for a closer inspection and repairs. Sadly, a life threatening health problem arose and surgery/treatments have prevented me from finishing this task until now. My problem now is that I cannot remember to save me how the fasteners/spacers(bushings)/washers (sequence)  go in the clutch cylinder and belt idler. I've searched at this site and on the internet and cannot seem to locate diagrams/repair manuals with photos/etc. that will help me with this task. Can someone direct me to a source that will solve my problem? Suggestions? Any help will be greatly appreciated.
Regards,
Bob
stevasaurus
Try this and see if it helps.  Down Load the TIPL part of this link..    :)
gwest_ca
This may have a better illustration in Part 3 - 2nd last page
Here is the operator manual in case you do not have it
Let us know if you still have questions.
Garry
  • Similar Content
    • KC9KAS
      By KC9KAS
      ISO of hydro motion control lever bushings.
      These appear to be parts # 5666 (nylon) need 2, # 5983 (Nyliner) need 2, # MW2195 (bronze) need 1.
      Please PM me here.
      Thanks in advance.
    • arminer8
      By arminer8
      I have a snowblower that has a bad bearing inside the auger on the chain side. Took it apart, and now I can't find a bearing like the one I need! One thing I need to know is if these parts are metric or American? If it is American, it is a 3/4" inside diameter, 1 5/8" outside diameter, 7/16" width. Anybody have a place they get them? Near Rochester, MN. It is a model 53321 snowblower I think as the model # plate is really scratched up.
