Countdown To Christmas!
Similar Content
By tntatro
Hello, I have a Wheel Horse 656 that I repowered with a 6-1/4hp Kohler K141T that was originally on a log splitter. I've been having an issue with it shutting down when it gets hot. It shuts completely off like the key was turned off, although this engine is a pull start. It will start back up and only run on low idle. It will start up and run normal when cooled down. I originally thought it was the ignition and replaced the coil and condenser with new OEM parts and it still does it. I don't believe it's the fuel either because it pumps fuel, has new fuel line, OEM filter and new shut off valve with the screen. I then took out the valves and cleaned them up and ran a 5/16" reamer down the valve guides thinking that the exhaust valve may be sticking when it gets hot. So far nothing I've tried has worked.
I'm curious if maybe I'm just working it too hard. The mower has a 35" cut and I mow a lot in top gear up inclines and it's been pretty hot out. The engine is within the wear limits internally, has plenty of power and doesn't smoke or knock. It's set to about 3,500rpm at full throttle with no load.
Any opinions or suggestions on what might be wrong or where to go from here?
Thanks, Tim
By jmack
I have a 522xi and noticed the muffler is glowing red as shown in this video? Should I be concerned and fix it to normal operating temps or is this expected?
Thanks,
JMack
IMG_1788.MOV -
By AndyZ
Operator manual #A-5274
Wiring
6 pages 7.31MB
Illustrated parts list link
Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
For 1970 electric clutch use Electro 12 model 1-7255
2 pages 282KB
We also have the 1971 tractor parts manual that followed
1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
By Kyle G Cantrell
Trying to restore a 1971 Wheel horse Workhorse 800 model 0100, It has a tecumseh HH80-110112D.
I cannot find any parts at all for this one, I’ve checked everywhere I can think online. This is my first restore, looking for some help to find parts or what I can use (swap) to keep it close to original but also functional.
Also the fly wheel has two **** that stick up off it that the coil passes and one is broke off. Is that a problem, I’m a mechanic but this thing is old and with no info it’s a guessing game.
Parts needed so far:
right side running bored/footrest
Left side engine cover
right side pulley cover
Ignition coil
Main drive pulley bearings
Hitch pin (goes through trans case)
*NEW TO SITE, WILL CHANGE IF POST INCORRECT*
By drewd
I need to buy tubes or new rear tires for my 1971 Workhorse 800. It has the original 22.5x7.50-12 Wheelhorse branded tires but sidewalls are leaking and one no longer holds air for more that two days. Searching websites brings up various sizes but not the original. Would a 23x9.50-12 fit this tractor? I have a 36" RD deck on it. Any other sizes work on this rim and tractor?
Thanks!
