T-Mo
520 Blade Extension Dimensions
T-Mo
If anyone can give me a rough drawing with dimensions for the front blade extension for a 520-H, I appreciate it.  I want to model one up and make a 2D drawing, and perhaps have one made for my 520-H.  Any help would be appreciated.  Thanks.
gwest_ca
Garry
Tankman
I cut and extended a frame and the angle rod, and release pin wire formed new.
Had a deal for a WH extension set which fell thru.
Works great. :handgestures-thumbupright:
Frame and angle control rod, both 4-1/2" longer.
Bent 12 ga CRS channels 4-1/2" long to match the Horse frame OD (outside dimensions). Tacked in place to hold frame solid.
Bent two channels 16" long with OD dimensions to fit into the Horse frame, ID (inside dimensions).
Stitch welded all after fitting and tack welding.
One piece 1/2" x 4-1/2" steel rod welded that into the cut angle control rod.
1/8" dia wire (rod) bent to fit the angle locking pin release.
