C85 backfires and quits after jump starting?
By
Mr Sweep, in Wheel Horse Electrical
Similar Content
By Josh Opitz
I have redone most electrical components and fuel of this kohler K341. new spark plug, coil, starter, battery, rectifier, Carb, rewired, but i have not done points. it starts up great idols fine. when I turn the throttle up it rises up to a certain RPM then starts to seize and puff black smoke and the throttle on the the carburetor jumps. Someone had told me it is backfiring and said i need to adjust the my air to fuel ratio. started messing with the governing arm and spring and thought it was helping but hasn't fixed it. any suggestions?
By classiccat
New member ...and another old-Iron guy here...with my 1st Wheel Horse tractor.
I was looking for something mainly for pulling an old aluminum boat (18' starcraft) around the property.
Capability to mow and haul yard waste would be a bonus.
2 weeks ago, a C85 showed-up on CL for a song.
He couldn't start it for me and it didn't take me long to figure out why...
This will be a running thread / rolling-restoration as I bring her back to her original, Black-Hood glory!
(DISCLAIMER: I'm an engine-wrencher ...I have the tendency to leave my foot off of the project's gas when the engine starts drinking it!)
By Team70R
Finally got me a lawn ranger and picked it up for an awesome price!! Now to get it running good. H60 Tecumseh won't run right. Goes from running great to running absolutely terrible and backfiring from the carb. I'm guessing the valves are messed up? Compression test rendered around 85 psi.
By JackHorse
Having a hard time justifying $300 to rebuild the spindles and replace pulleys on my deck. The deck is a (i believe) 05-36MS01 on my 1982 C85. I found these kits on Pat's and was wondering if anyone had tried to adapt them to a deck like mine? Thanks
By JoeM
Started another project this fall, I decided to install a 10 HP Chinese Diesel in a rescued C85. I worked a good price from Carroll Stream this spring on an engine and when I picked up the C85 in WV, I thought that would make a good fit. And like everything else I do, it got a little carried away!
Frist thought was making a worker, now slowly turning into a show pony.
The C85 black hood worked well because of the vast room under the hood. I made up threaded mounting blocks from 3/8†bar stock for mounting the engine. The engine was too close to the top of the hood to allow the compression release to rotate; I made a new hood hinge and raised the hood 3/4â€. A small teak on the side of the hood using a bar clamp and that made enough room to clear the air cleaner.
Then came new paint, tires, a stack, (with chrome tip), a sleeve hitch and much more. It is now about 90% now. Hope to be done next month; I will shoot more pics when completed.
Thanks for looking.
Joe
