dlaw90
42" RD Mulcher Blades
dlaw90
I'm looking to add a mulching blade to my 42" Rear Discharge (Model  78350). I would like to stack the mulching blade above the regular blade like this (picture is not mine):
post-11018-0-46927500-1398205634_thumb.j
I can't find a mulching bladewith the same specs as the Toro blade (Part # 106635).
Length = 14 1/2"
Width = 2"
C.H. Diameter = 3/4"
Thickness = 0.2040"
The Oregon 90-643 G3 Gator blade is close.
Length = 13 7/8"
Width = 2.5"
Thickness = 0.203"
Will the difference in blade length cause any problems? It seems like everything would still be balanced on the spindle and the Toro blade would still allow a full 42" cutting path. Am I missing anything? I have not verified that there is enough spindle length to accept both blades, but it appears this hasn't been an issue for others.
GlenPettit
That 5/8" difference is not a problem at all:
(1) Notice the overlap of the blades, of nearly an inch,
(2) you still have your original 141/2" blades on and working,
(3) the Gator blades tend to 'suck up' the grass blades for even better cutting.
There is just enough threads left on the spindle for the dual blades system, if concerned, you can get "shallow" or thinner 7/8" nuts -- just be sure your nuts are still good, with threads and "not-rounded" edges, and use a very thick heavy Lithi grease on the threads.
Keeping a clean deck helps a lot too, the additional set of Gator blades will greatly help reduce clumping, even on lightly moist cutting days.
Edited by GlenPettit
dlaw90
Thanks for the advice. I'm gonna go ahead and buy some mulching blades.
Rozlo
I've got a 42 rear discharge deck and it has a baffle all around the blades I've not looked into taking it off but I would like to take at least the back off so it will discharge the grass.  So you can cross blade these without a problem?  I've done it before on my other mowers with great success.   Need some input.
dlaw90
The spindles on my deck (Model 78350) weren't long enough for it to work. Even when I remove the thick washer (on the side of the blades closer to the ground), I can only engage half the threads on the nut.
It seems like the spindles aren't long enough or the blades that I used were too thick. I believe both nuts on the spindle are jam nuts, so I don't think I can find a thinner nut.
I haven't had the time to find a solution. Hopefully someone else can chime in with help
slammer302
I believe these are the blades ur looking for Oregon 90-643
dlaw90
 I used the Oregon 90-643 gator blade with a Toro #106635 blade. Unfortunately my spindles dont seem to have enough thread length
Edited by dlawrence529
GlenPettit
Normal Hardware stores (& Lowes) have thinner 3/4" nuts (our regular nuts are about 1/2" thick, they have ones that are just over 1/4" thick too, but be sure the thread count is correct).
••  Be sure to use an 'anti-stick' or 'Litho grease' on the threads, the direction of spinning tends to tighten up the nut.
••  Don't use a 'pipe wrench' on the nuts, as in first photo, it strips the outside  ----  pawn shops usually have a good selection of quality long-handled 11/8" wrenches, inexpensively;  use a 'box-end' on the outside nut and 'open-end' for under the blades on the spindle nut.
dlaw90
Thanks for the tip. I'll make a run to the hardware store this weekend. Do you use zinc, stainless, or galvanized nuts on the spindles?
pfrederi
Zinc is fine just use never-seize.  These thin nuts are often referred to as jam nuts.
dlaw90
Thanks for the help. It looks like the parts diagram for my mower deck shows a jam nut. Hopefully the hardware store has something thinner.
GlenPettit
Just noticed the washer (#9) in your diagram, that's something I've never used, didn't realize there should be one,
if used, could be replaced with a thin one.
dlaw90
Thanks. I tried replacing washer #9 with a 3/4" ID machine bushing (16 or 18 gauge?). Even if I remove washer #9 completely, I don't have enough thread length on the spindles. With washer #9 removed, about half the threads of the nut are engaged.
FYI. Washer #7 is paper thin. I'll pull the deck off and try to get some pictures this weekend.
  • Similar Content
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • Marc M.
      By Marc M.
      Hi guys I'm new to the wheelhorse world and i recently picked up a for 416-H and I'm looking to buy/install a plow put on it. I have found one on craigslist but I can't tell if it will work on my tractor or not, it is a wheelhorse plow though. Can somebody please send a photo or even a video of how to hook up a plow to a 416 or equivalent tractor?
      Attached is my tractor and the plow I'm looking at. Will it fix and what's it missing ?!
    • T-Mo
      By T-Mo-(Moderator)
      Drawing for both the short lift link, and the down pressure lift link for the front snow blade.
      Short lift link 105052
      Long lift link 7706 most likely replaced by 7706-01
      I drilled 3/8" holes in the bar and used 3/8" x 2-1/2" Gr.5 bolts. Cut the threads off.
      Weld the head of one bolt to the bar and try it for alignment. I ended up installing the 2nd bolt from the other direction and welding the head only. This provided 1/4" of offset and the pins are square to their attaching parts to minimise wear.
      Drill holes in the bolts perpendicular to the bar for spring pins. Use a countersink to ease the edges of the holes.
      With the holes drilled like they are you now know where they are and you can instal the pins blindfolded.
      With manual lift the float is built in - everything floats including the lift handle.
      With hydraulic lift the float is accomplished by connecting the bottom of the link to the slotted hole. Down pressure is still available when the pin hits the bottom of the slot.
      Garry
    • Goldann520
      By Goldann520
      Hey guys, @wheelhorseman, @WVHillbilly520H, brought this stuff home today. Big question did wh make a gooseneck trailer like this? Really hope so, paint looks right and came out of the same lot as the rest of this. Owner swears he had blade and blower on the 414-8 Which means it'll fit my 312-8. He talked me (or bribed) me into taking tractor with me. Got the weights and chains too. $440 for all of it. Tractor runs but has fuel delivery problems.
    • Sarge
      By Sarge
      Since I've finally got some time with this D and not puking oil all over itself it's time to address a few small issues . Biggest one right now is how that blade engages the ground - it always wants to sit a few inches lower on the right side and always puts more force on that side as well . When I rebuilt the frame I made certain it was squared and flat to the head part and the blade - it still measures out perfectly with the rear mount and the blade's cutting edge staying on the same plane . But , trying to do light grading work and leveling material it always wants to cut more on that right side - I suspect part of this is the weight of that handle , the solid steel cross shafts and sub frame for the whole assembly . With those parts previously cut loose I was quite surprised at just how heavy that stuff was - probably close to 35lbs of steel . With that weight hanging off one side of the frame I suspect that's the root cause of the issue - anyone got an opinion on this or ran across the same issue ?
      I've considered either adding weight to the left side of the blade or maybe add a spring to the frame to help correct it - what have others done or am I by myself on this , lol ??
      Sarge
