Similar Content
By Jayzauto
I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint. Engine has been replaced with an identical Kohler KT-17 Series 1. New Carb has been installed. Battery, solenoid and cables have been replaced, starts great. Installed new Tires and Tie Rods. Installed radial bearings in spindles, so it steers beautifully. Fuel line has been changed, as well as headlights. Bew mule drive and belt fot tiller and functions as designed. I'm sure there is other items that have been done. Very reliable machine. $800/BRO
Selling all my WheelHorse items and moving South. Have other tractors ad parts if interested.
By Govlarry dale
Hi guys i bought a Ford walk behind Rototiller and it runs perfectly however i dont think, well i know the belts are on wrong. Any idea where i might find a little help? Series RT T4
Component 9607426
Serial YC00209 83222
FORD POWER REVERSE
THANKS JUST IN CASE
By jetmandan
About a year ago scanning my local craigslist, I found a newer Toro / Wheel horse 36" roto tiller for $50. Mounted up to my 74, C-160 after I had to trim off a bit of the rear axle mount locking bracket (it's length was bumping into idler pulley). Now I needed the mid mount belt setup, I have a well equipped shop at home so all I needed was some measurements. Built my drive setup close to member "Lost Pup" and his post here
The mostly finished bracket, waiting for 141 x 1/2" belt to arrive, bought off greed-bay. Will tack the set-screw shaft locks in place after belt fitted.
Pic from underside, spring is probably from an old bed mattress. It was just in my junk pile and looks close to being correct size.
Side pic of my over powered C-160
Tiller mounting shot, the electric lift is getting weak, has to work pretty hard to lift roto tiller. Plans are to remove and sell it off then replace with my own linear actuator setup.
Dan
