TravelinJavelin
C-120 tranny slop issue?
TravelinJavelin
I 'm not sure if its a problem or not or nature of the beast? but when I go down hill it will take off or coast for a second then catches up to itself  and all is fine after that it does have a axle seal leak on the right side not sure what to look for? are the seal on the outside axle tube or does the tranny got to be pulled to change it?
Edited by TravelinJavelin
Racinbob
A little bit of that is normal as the gears switch from go to whoa on a downgrade. All the seals can be replaced without tearing the transmission apart. The hardest part on an axle seal is often getting the hub off. :)
