TravelinJavelin 620 #1 Posted April 23, 2017 (edited) I 'm not sure if its a problem or not or nature of the beast? but when I go down hill it will take off or coast for a second then catches up to itself and all is fine after that it does have a axle seal leak on the right side not sure what to look for? are the seal on the outside axle tube or does the tranny got to be pulled to change it? Edited April 23, 2017 by TravelinJavelin Share this post Link to post Share on other sites
Racinbob 11,238 #2 Posted April 23, 2017 A little bit of that is normal as the gears switch from go to whoa on a downgrade. All the seals can be replaced without tearing the transmission apart. The hardest part on an axle seal is often getting the hub off. 2 Share this post Link to post Share on other sites
