pfrederi
O rings for D Series Hydro manifold
pfrederi
I know rings are still available from Toro (or were awhile ago) but they aren't cheap.
I have used rings from McMaster with success and a whole bunch cheaper.even buying  bags of 50-100.
O rings are designated by Dash #s
There are 3 O rings
WH# 971105 (Small)  Dash # 015
WH 971018  (Lge)    Dash # 018
WH 103184  Backup   McMaster # 5288T124 (Also Known as "Backup for Dash 018")
The sealing washer is NLA.  I use Stat-o-seal 1/2" sealing washer  McMaster# 93783A033 .  These are in a 10 pack I have some extras if you need one i can mail you one)
You can also find copper crush washers at auto parts stores that will work
BaySide1
In buy my O-Rings from Mechanics Bliss on Hermon St. in Worcester, MA
They have everything and you can buy 1 of each if need be
pfrederi
41 minutes ago, DavidP said:
Which O-rings do I want or the manifold from? https://www.mcmaster.com/dash-015
Dash # 015
Dash # 018
Got your PM will send a set out tomorrow.
DavidP
Got them in the mail today.
Thanks a ton.
