Similar Content
By 87 312-8
looking for mule drive bearings for a 36 inch rear discharge deck 1986/87 312-8, thank you
By OHLB
Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
By Rob R
Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now! The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
By Ifixoldjunk
So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
Like would generic adjustable go-kart tie rods do the trick?
