608KEB
I tried to downsize
HorseFixer
Did ya get it back at a cheaper price? Or was he a friend?
953 nut
24 minutes ago, 608KEB said:
The war dept. :bitch:told him him he had to chose between a motorcycle or the WH.
Image result for them's fightin words
  • Like 5
Shynon
I like the heading "I tried to downsize":ROTF::ROTF::ROTF:
  • Haha 2
608KEB
I bought it back for $30.00 less. He put a new solenoid  and starter on it. The solenoid just needed to be cleaned up. The starter that was on it was new. Now I have 2 new starters. The original  starter also worked fine from the original owner. I'm going to put the original  starter back on and add a hour meter. :banana-linedance:
  • Like 3
Wishin4a416
Good for You!!!!
my new toy
I understand your problem/ how come they never say one has to go me or the WH
my new toy
Because they know the answer//////////
  • Haha 1
608KEB
I haven't  bought any Garden Tractors  in more than 3 1/2 years. I still Love the Wheel Horse's.  I was running out of room.
  • Sad 1
ebinmaine
I'm pretty happy about the fact that the "War Dept" here now has two of her own in the herd...
  • Like 5
  • Excellent 1
wallfish
No problem honey. Here's your new push mower and snow shovel. It's so wonderful you decided to take on these chores.  I'm going for a long ride with my extra time. Luv you!
  • Excellent 1
  • Thanks 1
  • Haha 3
  • Heart 1
WHX??
I know yer sitting on a couple of LSE's should you really wanna downsize 608... :lol:
608KEB
I have one WH LSE. #143. 398 hours. I'm not looking to downsize anymore.  I just wanna keep what I have. When I bought the LSE, I also picked up a 1995 520H with 92 hours. I just cleaned the carburetor  a couple of weeks ago!   They both run excellent.  I felt guilty about using both tractors. So I put
 them on a shelf for now.
608KEB
:text-bump:
  • Haha 1
RandyLittrell
Ya just gotta rub it in, don't ya!!:ranting:
Randy
  • Haha 2
WHX??
Older thread I see 608 but should you feel the need to downsize anymore call me first .. we have a duty to keep horses from crossing state lines ya know! :lol: Side's  you keep ticking me off by not coming to my plow day I may have to low ball ya! :ychain:
  • Haha 1
Shynon
Don't you need to call someone else????? That's downsizing :ychain:
  • Thanks 1
  • Haha 1
608KEB
I'd like to come to your plow day. But, I organic grain farm and am busy plowing and spreading chicken poop! I hope you get over it.:D
  • Haha 1
Pullstart
Hey Jim!  Sounds like the local ‘608 needs some organized plowing visits!  How bout you wrangle up a team a’ horses and make a hit on his field!  I’m sure you’ve got some tractor mafia connections to make that happen, eh?
  • Haha 2
  • Similar Content
    • KC9KAS
      By KC9KAS
      Need assistance! 1977 Wheel Horse C-120 hydro. I sold it to a young fellow last fall. His dad said he put a new battery in it but it still failed to turn over to start. I checked the only safety switch (with an ohm meter) and it is working correctly. I checked all the wires (ohm meter) and they tested ok. I did come to the conclusion the 20 amp AMP gauge was bad. I installed an old one that I had and it turned over and started right up. I already had the voltage regulator wires disconnected and read 36 VAC from the stator. When I attached the wires to the (fairly new) voltage regulator it would immediately cause the engine to sputter and die. The voltage regulator is grounded directly to the negative post on the battery. Once the wires were removed from the voltage regulator it would fire right back up! I am at my wits end trying to figure this one out! Would a bad voltage regulator cause the engine to quit running? I may have to remove a voltage regulator from another known good machine and try it. Anyone have any suggestions?
    • JasonMc
      By JasonMc
      Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
      Jason
    • WHX??
      By WHX??
      Sadly Dan @Achto informed me the the other day of a 857 and a C-120 that was deposited at his local county dump. Dump rules are  such that once it hits the ground it stays due to junkyard dogs going to fisticuffs over scrap steel. Understandable  Despite some hastily made plans of bribery,  chicanery and/or hook or crook to rescue them we failed miserably. We may get drummed out of the Mafia for that one.
      I'll let Dan fill you in on the details if he has the stomach.  I would like to believe that that our beloved  ones would be smelted down to produce more tractors but then I wake up from that dream. Sorry no bone yard pics not that we would want to see them.
      Dan asked me if he had a problem over grieving over these lost gems. You decide... So in memoriam I feel it is quite nescessary to post pics of our lost loved ones. Since I don't have a C-120 here's what I have of a 857.  Please post your pics of either models. True story, I wouldn't hose you guys and not just fishin  for
    • 608KEB
      By 608KEB
      One seat spring is about 1/4" lower than the other one. Has anyone had this problem. If so, what'd you do to fix it?
    • Tuneup
      By Tuneup
      Homer is a typical Southern man. When a tool breaks, he moves it to his backyard to be repaired another time. Turns out I'm the repair guy and have been attempting to barter for an old C-120 and a Commando 7 buried in the yard. He surprised me with the C-125 black hood a while ago after numerous mower, chain saw, weed wacker and whatever repairs. The horses are all out of a shop in Joplin now gone after the big blow... Soooo, 1 repaired old Sears LT and another that I took apart just so he could see after running without oil that the cam was in 4 pieces and the rod in 5 and he said I could have the 120. We pulled it out of the dirt with 4 flats, destroying several ant mounds in the process. Truly, not bad condition thanks to Homer's attention to the use of tarps. He tells me the 301 was bored .030 over and his mind is sharp for a 92 year old so I'm inclined to believe him. May be able to save that Commando in the near future if I repair that old Bolens GT14 first - and so on. So, my collection is now at a lowly 2. I don't think I'll restore this - will just make her a reliable runner and make the wife happy The deck can use a little metal but seems salvageable. Another C saved!
