coach717
Coach needs some coaching (help)
coach717
Newbie here I bought an old 1988 Wheel Horse 111-6 it's a rear engine. I picked this up for $75.00 Put a new ignition switch in cleaned the carb installed a new battery and it fired right up. Amazing! What I havent been able to do is keep the pto belt working so the deck cuts. Is there an adjustment I can make to help insure that the belt stays engaged? Help I don't want to use that walk behind mower!!!
Thanks,
Coach717 needs coaching
farmer
:text-welcomeconfetti:coach717
 I'm unfamiliar with that machine, but sure there with be others on here who are and can help you out. What I would suggest (if you haven't already done it) is try to find the model number on your mower. It's usually on a little plate with a serial number. Go to the Toro lookup site, follow the instructions and you should be able to identify all the relevant components, with part numbers. Maybe you have broken spring, tensioner or whatever, ....it's a place to start.  :handgestures-thumbupright:
gwest_ca
Welcome to the forum.
We do not have much on that model. The wire belt guides are usually adjusted so they almost touch a belt when the belt is tight.
Garry
  • Like 3
SylvanLakeWH
Retired Wrencher
coach717   :WRS:  Good luck with your 88 111-6 Hope it all works out for you.
rmaynard
I looked through my dusty archives of old manuals, links and miscellaneous stuff and found this. Don't know if it is the same, or if it will help you, but here is a link to a manual for the 111-5 mower.
http://www.ornery.net/2009-05-30/pages/DSC04100R.htm
  • Like 3
Achto
:WRS:
BOB ELLISON
This is what I could find hope it helps
Best I could do
Here are the possible model numbers for the 111-5.
33-11B501, 111-5 Rear Engine Rider, 1985
33-11B502, 111-5 Rear Engine Rider, 1986
33-11B503, 111-5 Rear Engine Rider, 1987
B3-11B502, 111-5 Rear Engine Rider, 1986
B3-11B591, 111-5 Rear Engine Rider, 1987
There should be a decal/plate on the unit with the number on it. Go to
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
You can view the "Product Features" which lists the engine used on each model plus the illustrated parts lists for the tractor.
Here is another link that prices the parts still available from Toro.
http://www.partstree.com/parts/
Put Toro in the 2nd box and the long tractor model number in the 3rd box.
You can also put Briggs in the 2nd box and the engine number in the 3rd box.
You could try ordering a manual from
https://lookup3.toro.com/request/request.cfm
Enter the long model number and select "Riding Mowers" for the product type.
Lee1977
I think your saying that the blade won't stay engaged. I looked at the PTO parts drawing on "Parts Tree" it's a belt tightening system. With out it running engage the PTO and check to see how tight the belt is. If it is loose you may need a new belt, also check the idler pulley to see if it turns freely.
Daddy Don
WHX??
:WRS: Coach
Sounds like the guys got you pointed in the right direction, let us know how it comes out!
coach717
I want to say thanks to all for the overwhelming responses. I think I've got some good info to move me in the right direction. I will let you know how it works out!
Coach717
jay bee
:text-welcomeconfetti: Coach to :rs: It looks like you just got a little taste of how helpful and friendly these people around here are.  I love this place!!! :greetings-clappingyellow:
Jim
  • Similar Content
    • davem1111
      By davem1111
      I'm trying to figure out how to fix two problems:
      1. Drive belt from PTO to deck keeps flipping over between the PTO and the mule.  Everything looks okay, belt runs right between mule and deck. It cuts just fine, but I'm concerned that running the belt on its back through the PTO will shorten its life a lot.
      2. PTO handle kicks off at random times while engaged. Not doing anything unusual, just cruising along mowing, and boom, it flips back.  Missing spring maybe?
      Any ideas?
    • deere173
      By deere173
      Hello again. I'm helping a friend with a problem with his 312-H tractor and 42 inch rear discharge mower deck.  We've done a lot of work on this machine in the last year and the last problem is that the pto belt, or deck drive belt, is wearing out pretty quickly.  This will be the second belt this summer.  I have tried every belt routing I can see as possible, including reversing the idler pulleys on the forward right side of the tractor frame. We are using belt #108834, 1/2' x 98".  Is this normal??
    • rogden
      By rogden
      Hey everyone I am new to Red Square, I just got a new to me, c160. I believe its a 1977, it came with a  rear discharge three blade 42 inch mowing deck. Listening to the 16hp kohler, idle sealed the deal for me, you just gotta love that sound!
      It had a brand new huffy blue belt on the pto running to the deck when i bought it. To make a long story short, it spewed white smoke under any load and burned up the belt in about 30 minutes. I did some research and determined the belt must have been to loose, so I cleaned up the tractor, went and got another huffy blue belt 96 x 1/2 installed it...tightened that mutha up and cut some grass.  I have about 2 acres and the grass was tall but about a third way thru I noticed the belt flopping around like it was loose. Sure enough it was, I tightened it again...and again...and again. By the time I was done cutting the grass the belt looked like it had been on there 10 years and i was almost out of adjustment on the mule drive. The belt was thinner and badly frayed.
      Now when the first belt failed i took the deck off checked out the spindles, they were not loose no rough spots and i greased them. I also checked the mule pulleys, I didn't see any way to grease them but they spun nice. I pulled the pto hub off checked both bearings and greased them with lithium grease. Everything looked good!
      After the second belt was shot I decided to try and diagnose the problem. I can spin everything with my hand, with the belt on, it feels ok. But what i noticed was the pto belt as it comes off the engine side pulley of the pto hub the side of the belt rubs the side of the pulley on the pto. It rubs on the tall side or  the friction pad / clutch side. I stood up and looked down and saw the belt was running on a angle inwards towards the motor as it goes down the the v pulley which is closest to the motor on the mule drive.
      So I think this is the problem, it makes sense to me anyway that rubbing on the side of that belt would cause heat and would fray the belt, which is what I have. I just don't know how to adjust the mule to align the pulleys. Maybe its not the mule and the motor slide on the  on the mounts causing the mis-alignment.
      Any help would be much appreciated folks!
      Best Regards,
      Rick
