WVHillbilly520H
New "shoes" for a horse
AMC RULES
:think:  Can you hunt from a tractor there?
WVHillbilly520H
Tractor, truck, ATV,  by foot ,hanging out the sliding Patio door, off the table on the deck, it's zoned county/agricultral, ain't had the five-0 called on me yet :violence-blades:,just gotta be stealthy
  • Like 5
AMC RULES
Ain't it hard to be stealthy...
when you've got an audience?  :ychain:
WVHillbilly520H
That's the family, they see ,hear not speak no evils, of the samurai :laughing-rofl:
WVHillbilly520H
Didn't know whether to start a new thread or just add to this one, since it's another new pair and different brand here goes, all the "off brands" seem to run smaller than stated and Carlise and Firestone pricey, I decided I would be the guinea pig for the OTR LAWN TRAC R1 23x10.50-12 (they also have the 16x7.50-8 R1s), so here's the pics as they arrived today will be going on the anniversary 520H blower rig and fluild filled too, Jeff. 1st couple compared the used tires I have on there for years, then the Nanco brand on the '95, my ATV,  and the eMax...
  • Like 7
WHX??
They do look to run a tad small and definitely a different thread pattern. Almost like a cross between an AG and a R-4. Care to share your source and $$ Jeff?? More :text-coolphotos: please when you get them locked and loaded.
ACman
OTR’s are what came stock on my 2004 Kubota BX2230 . I have both the Ag’s and turf for it and they’ve been a good tire . They’re a soft compound tire and bite good. I do have a flat on one of the rear ag’s . My son told me they couldn’t patch the tire because of how it is made in the inside. Could you post a pic of the inside of the tire. I’ve yet to see a tire that couldn’t be patched on the inside (I hate pluggs) but I’ve been outta the loop for seven years now. Maybe things have changed.
Edited by ACman
  • Like 3
WVHillbilly520H
They do look a hair shorter but not aired up, but definitely wider than the Nanco/Deestone on the '95, and the Nankangs on the anniversary, I do believe the Hi-Runs at TSC are very close to actual 23x10.50 size as well, but next to the eMax and ATV yep small, Jeff.
Might have to get the matching fronts and here's the specs on the Carlise... @ACman, I get you a pic of the inside carcass tomorrow, Jeff.
  • Thanks 1
Horse Newbie
When mounting( he said "mounting") :Dthe AG's; do they have directional arrows on the sidewall, or isn't it just you Mount them where as the tire spins( if it does) it will push the dirt/ mud to the outside, or is it supposed to push it to the inside of the tire ?
Also @WV Hillbilly...if you could, please elaborate on the " theory" of mounting the AG's this way, or that way.
I used to work at NASA and we only paid slightly more than these prices for tires for the Space Shuttle:ROTF:. Can't believe tires cost that much, but there it is right in front of me.
  • Haha 1
AMC RULES
:rolleyes: That's nothing...
try pricing bicycle tires.
  • Haha 1
WVHillbilly520H
@ACman, as promised inside tire pics, hope this helps, also what a shop done last year for me on my Trailblazer as I ran over a board with a long staple left 2 holes within 1/8" was use a die grinder with scuff pad to roughen up the the rubber on the inside so the patch would actually stick, ...
Theses tires do have the direction arrow on the sidewalls but being around farming since a child it's just pretty much how they always mounted them and with that being said the lugs pointing that way will grab and pull going forward while pushing the loose soil ect out but when in reverse they do seem to clog up faster (bottom pic in rotting grass and wet clay) so some that run dual wheel usually mount one pair forward the other backwards in theory helping traction both ways, Jeff.
  • Like 3
Sarge
It has to be an issue on how the belts are done in some tires - my local tire guy I've trusted for 30yrs has refused some of the ag tires for some reason due to the belts . He said the patch will not hold the way they flex or something to that order . I use the plugs and have never had a problem with Safety Seal brand - even tried pulling a couple old ones out and they are stuck solid in there , even on a nearly bald and worn out tire .
Not sure if it's the same maker , but so far the BKT's seem to run true to size if not slightly taller than advertised - I like the front ags I put on the D and they hold it's steering well even in the snow last night . I'm about ready to yank the American Farmer's off the rear - they are horribly short but bite just fine with the chains/weights on it but I hate how the tractor sits now with a negative rake . Should have went to a 29" or something...ugh .
Sarge
Horse Newbie
Sarge
I've used plugs too @Sarge and they seem to work fine. Once in a blue moon, I'll have one leak, but usually by the time I go to an inner tube it's dry rotted and/ or cracked tires.
ACman
@WVHillbilly520H thanks....for sure that tire can be patched. Never again taken a tire back to that shop. They probably didn’t want to mess around with a 26x12-12 tire and rim . I wish I knew how many tires I’ve fixed and mounted back in the day . I always used a radial tire patch even on Innertube’s . Just the way I was taught I guess :confusion-shrug: .
Edited by ACman
WVHillbilly520H
I guess that BX has small tires compared to my eMax 27x12.50-15 rears 20x8-10 fronts and my Kioti has 23x8.50-12 fronts with 12-16.5 or 33x12.5-16.5 rears, and yes if they can't patch then they obviously don't know what do to it don't want to, Jeff.
ACman
Yes the BX series to me is just a overgrown garden tractor :twocents-02cents: . I just couldn’t pass up the incredible deal this widow gave me . 23hp , 4x4 with diff lock , 250 hours , FEL , 60” mmm deck , both sets of tires and a brand new DR 3point chipper/shedder all for $5000 (7yrs ago and it’s a 2004) :woohoo: . Plus she just kept throwing things from the barn on the trailer (she was selling the house and getting rid of everything). She told me she just wanted it to go to a good home and I just happened to be at the right place at the right time :) .
  • Excellent 3
WVHillbilly520H
@ACman, the eMax isn't much bigger than the Xi series vs the classics, but the the running gear is all cast iron/steel the hood and fenders are plastic on mine but the '17 newer are steel now.
WHX??
Interesting fellas.. thanks for the info on the OTR's. Would be interesting to see how they perform on a (dirt) plow tractor since that's what I am looking for a set for. The MN boys @Shynon say the Firestone flotation 23's are the best (they been plowing long before I) so I believe them but being as cheap as I am can't get past the price point. I do like the price of your OTRs Billy and I may just get a set to "try" out and can always swap them out with another tractor if they don't pan out. Trouble is with us furrow dogs as  @PeacemakerJack so eloquently puts it we plow under vastly different conditions from location to location. I have a set of Tru Powers on a plow tractor in 23-8.50 and they work extremely well in loose sandy soil but haven't worked them in clay or hard packed clay yet.
Note the skinny profile on 8.50's
  • Excellent 1
ACman
@WHX14 I’ve seen no problem with traction with the ags or turfs (snow, ice, dirt) on the Kubota .
  • Thanks 2
WVHillbilly520H
@WHX14, Jim the old Nankangs on the anniversary have done well in most conditions from mowing, gardening, snow removal but they were new/used when I got them as they sat outside mounted on a project that never got finished, the new Nanco/Deestones have been ok but that rotting grass/composte pile on clay even with weights and chains I didn't have a chance (refer to above post), I'm thinking with the way these are designed with a bit more center section then sloping outward would bite and clean themselves faster before clogging (first couple pics I posted of these), as soon as the cold snap is over I plan to pull the weights and get them exchanged before the snow actually hits, and if they do good I'll get another pr for the '95 and save the Nanco brand for a future project(maybe) , and yes $300+ for a pr of Firestones kinda sucks don't it when you can reshoe 2 tractors for that $, Jeff.
  • Thanks 2
Sarge
I don't honestly think anything has ever beaten the 23* Firestone ags yet in the dirt - but yeah that price tag hurts . I will say this - never been disappointed with the Carlisle Tru Power in any ground condition - even deep mud they just keep pulling - only been stuck once and that was due to the blade getting hung up in a ditch . They will tear up some stuff if you ever even slightly spin one , though...but seem to wear like iron too .
Sarge
  • Excellent 2
WHX??
I agree Sarge... I paid 200 for both Tru powers in my pics and my Firestone guy even mounted them for that. Going to go see what he wants for a set in 10.5 but I'm guessing around 120 apiece and and find out what he wants for 23's but in in the end I think I will end up with Jeff's OTR's. I ain't made of money. Jeff on those 16x7.50's have you got them on the front of something?
You also bring up a point about how they clean themselves, I have videos of the the guys plowing with the 23's and they are PACKED with clay yet keep trucking. Have to see if I can post them videos up.
aHorseofCourse
I have the OTR's on the front, 16 7.50-8, and tru powers on the back.  Seems to work great in snow and dirt.  Even plowing snow it turns on a dime, I have front weights on too tho.  They seem to be a soft compound and might wear quickly.  All the little nubs are worn off already,  the rear tru powers still have the nubs and were installed at the same time.
  • Excellent 5
littleredrider
It hurt like hell but I bought a set of the Firestone 23 degrees. After shipping $345 I think. It says 8 to 10.5' rim, but with the mounted on the 520s rims, the tread was the same width as the rim, meaning NOT 10.5" wide. The sidewall is vertically straight up/down from tread to bead. I haven't had much chance to try em out, think mowed once, and only 4-5" of snow, and even going in the yard they did fine, didn't spin a tire. On the g/f's tractor, I put ATV tires on it, 25x12x12 Super swamper vampires. They have 1.5" deep lugs, directional, and when mounted on 8.5" rim, fit under the fenders without lifting or cutting. Its close, but fits. I had to move the hubs way out, cause of the side lugs they have, hit the brake band and close to filter. But again, had limited use of them. But don't think I will get stuck, played in the mud little bit. There is a beaver pond on our property with a small stream feeding it. I take the 4 wheeler thru it so gets turned up sometimes. But there is soft mud in spots. I backed down into stream, and  it sunk bout to the middle of the rim, thought I was gonna flip over lol, and pushed the lever forward, it just pushed my thru without even spinning a tire. They are 6 ply I think, and even with no air in there, doesn't squat all that much. If it was gonna be warmer than -11 I'd snap a pic or two...Oh and I paid $35 a piece for the tires, $25 each shipped, which I think is asinine. But still cheaper than ANY tire bigger than a 23" tire.
  • Excellent 1
WVHillbilly520H
I braved some cold temps this evening and pulled the weights and fluid filled tires off the anniversary hoping I can get the tire shop to swap them out for me after work tomorrow(short day O/T), anyways here's a couple more pics ,the old tires are Nankang brand I bought used, last pic laying flat on side in truck bed, Jeff.
Edited by WVHillbilly520H
  • Excellent 1
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
