HamptonT 33 #1 Posted April 7, 2017 I need some advice/opinions. I have a 314-8 that came with a set of rear wheel weights. The rear wheel weights were an off white color that looked original. So.....I wire brushed them and repainted them off white. I now have a set of matching front wheel weights. They are red. Not sure if red is/was the original color. Do i wire brush and paint to match the rear or leave them red? Thanks 3 Share this post Link to post Share on other sites
farmer 1,075 #2 Posted April 7, 2017 If they were mine I'd go red all round, here's a pic of mine. 3 Share this post Link to post Share on other sites
evanloock 221 #3 Posted April 7, 2017 (edited) White was the color used in the 60's up through the mid-70's. They switched to red thereafter for the cast wheel weights. The 1976 brochure shows them in red, while the 1975 accessories brochure shows them in white. Edited April 7, 2017 by evanloock 3 Share this post Link to post Share on other sites
Thegearhead0324 1,256 #4 Posted April 7, 2017 I have a completely different set up, but I like bright red to pop out with the bright white wheels. I'm a "poppy" kinda guy. 6 Share this post Link to post Share on other sites
953 nut 56,159 #5 Posted April 7, 2017 The choice of color should be whatever you find the most pleasing. If they were mine I would have them match the rims, but that is just my opinion. 3 Share this post Link to post Share on other sites
HamptonT 33 #6 Posted April 7, 2017 30 minutes ago, Thegearhead0324 said: I have a completely different set up, but I like bright red to pop out with the bright white wheels. I'm a "poppy" kinda guy. I like those inside wheel weights. Are they as hard to find as the front wheel weights? Share this post Link to post Share on other sites
Thegearhead0324 1,256 #7 Posted April 7, 2017 The ones I got are made for a cub and were yellow. I wanted inside ones because of hubcaps on the outside. Those actually fit over the center hub perfectly which is why I chose them. 2 Share this post Link to post Share on other sites
Lee1977 6,866 #8 Posted April 7, 2017 I lIke RED. d. Share this post Link to post Share on other sites
rjg854 11,572 #9 Posted April 7, 2017 My wheel weights are the same color as the rims. They are on the Commando w/the grader blade. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #11 Posted April 7, 2017 Cub Cadet weights painted Duplicolor silver to "match" the wheels the weigh about 30# each the you have are heavier then there's Massey Ferguson split weights that are about 45# and the wheel covers will over them I did both just today, Jeff. 2 Share this post Link to post Share on other sites
Thegearhead0324 1,256 #12 Posted April 8, 2017 I actually never knew weights were out there to fit inside a wheel like that, now I'll be on a search. Ol lady's gonna hate me now..... more money 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #13 Posted April 8, 2017 36 minutes ago, Thegearhead0324 said: I actually never knew weights were out there to fit inside a wheel like that, now I'll be on a search. Ol lady's gonna hate me now..... more money I was lucky enough to stumble upon them cheap, checking they are asking around $250/set, Jeff. Share this post Link to post Share on other sites
Thegearhead0324 1,256 #14 Posted April 8, 2017 I noticed.... ouch.. gonna have to wait a while lol Share this post Link to post Share on other sites
cschannuth 3,817 #15 Posted April 8, 2017 9 hours ago, HamptonT said: I need some advice/opinions. I have a 314-8 that came with a set of rear wheel weights. The rear wheel weights were an off white color that looked original. So.....I wire brushed them and repainted them off white. I now have a set of matching front wheel weights. They are red. Not sure if red is/was the original color. Do i wire brush and paint to match the rear or leave them red? Thanks I believe these shown below are the same weights in red. I like them in red but kind of miss seeing the deep dish white wheels. 4 Share this post Link to post Share on other sites
570 Productions 51 #16 Posted April 8, 2017 I painted mine black but I only use them in the winter, because my 1962 502 the rear bearings are bad because they were left on all year. Share this post Link to post Share on other sites
Adams94 1,068 #17 Posted April 8, 2017 I painted mine Regal red and I like them, I have a set of rears that aren't for show just snow plowing, they are black but they are not oem. If I find correct rear ones they will be regal red to! 3 Share this post Link to post Share on other sites
bmsgaffer 2,046 #18 Posted April 14, 2017 On 4/7/2017 at 11:06 PM, 1Steinway said: I painted mine black but I only use them in the winter, because my 1962 502 the rear bearings are bad because they were left on all year. The bearings in the transmission are rated to many thousands of pounds. If they went bad on you, it wasn't because of 100lbs of wheel weight, they were probably already getting ready to go. All that to say, replace the bearings and dont feel bad about running weights year round, these tractors can handle it. 2 Share this post Link to post Share on other sites
WHX?? 49,485 #19 Posted April 14, 2017 Wheel weights don't put a lot of stress on the bearing since no weight is being added to the tractor, just the tire & rim. Color doesn't matter as long as it's not green or yellow....then we might have to put our foot down! 1 Share this post Link to post Share on other sites
570 Productions 51 #20 Posted April 15, 2017 11 hours ago, bmsgaffer said: The bearings in the transmission are rated to many thousands of pounds. If they went bad on you, it wasn't because of 100lbs of wheel weight, they were probably already getting ready to go. All that to say, replace the bearings and dont feel bad about running weights year round, these tractors can handle it. I know, but I drive the WheelHorse to my mowing jobs and I noticed and clunk from the wheel weights moving around. In hi 3rd gear. I now use them on my 67 867. Share this post Link to post Share on other sites
HamptonT 33 #21 Posted April 19, 2017 On 4/7/2017 at 2:18 PM, Thegearhead0324 said: I have a completely different set up, but I like bright red to pop out with the bright white wheels. I'm a "poppy" kinda guy. I like those inside wheel weights. Are they as hard to find as the front wheel weights? I went with white.... Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #22 Posted April 19, 2017 (edited) How about silver or blue? The silver ones(same as the gearheads' red inside weights) are Farmal Cub/CubCadet and the blue ones are Massey Ferguson then you tuck 'em under a set of custom caps, Jeff. Edited April 19, 2017 by WVHillbilly520H Share this post Link to post Share on other sites
cschannuth 3,817 #23 Posted May 19, 2017 On 4/19/2017 at 4:37 PM, WVHillbilly520H said: How about silver or blue? The silver ones(same as the gearheads' red inside weights) are Farmal Cub/CubCadet and the blue ones are Massey Ferguson then you tuck 'em under a set of custom caps, Jeff. I wonder if my 7" wheels would be deep enough to accept the massey weights and still allow the hubcaps to fit like they do on your 8.5" wheels? 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #24 Posted May 19, 2017 @cschannuth Craig, later today or tomorrow, I'll pull a cap and check/measure how much clearance I have then minus your 1.5" and let you know exactly, but from putting them on and pics I'm fairly certain they should, Jeff. 1 Share this post Link to post Share on other sites
cschannuth 3,817 #25 Posted May 19, 2017 4 minutes ago, WVHillbilly520H said: @cschannuth Craig, later today or tomorrow, I'll pull a cap and check/measure how much clearance I have then minus your 1.5" and let you know exactly, but from putting them on and pics I'm fairly certain they should, Jeff. Thanks Share this post Link to post Share on other sites
