Need some Assistance / Advice on my K301 47147B
By
69-Raider-10, in Wheel Horse Electrical
Similar Content
By Hardy6
Hi I recently got an old charger 12 that had been sitting in a friends backyard for at least 20 years. The engine spins over and the starter works but it has no spark, I’ve been looking online for some solutions but I can’t seem to find any other charger 12s with my ignition setup. It seems to have a sort CDI box but I’m not sure. Does anybody know how this works or any tips on how to test for where the problem is ?
By Slightly Discombobulated
I need some help. I picked up a 1968 electro 12 (1-7235) that I'm assuming is an early model built with a leftover 67 engine because the engine patina matches the tractor and it has an external generator/starter instead of the magneto. It's a k301S-4712B. I bought it knowing that the engine turns freely and that it had no spark. Being 52 years old I figured it deserved some fresh ignition parts so I replaced the coil, condenser, points (cleaned and set to .020), spark plug (.035), and plug wire, and I still cannot get a spark at the plug or through my spark plug tester. It turns over okay and I've got 12 volts to the positive terminal on the coil. It's been many years since last worked on this type of ignition system and I'm stumped. I would appreciate any input/suggestions you might have. If it were something newer I'd suspect a safety switch but I can't see that this has any.
By Gas Man
I just bought my first Wheel Horse. She's a c-175 Automatic. Sounds like I stumbled onto a Crappy example of a Kohler as it has a KT17 series 1. The previous owner said "She was running when I shut her off" That was around 2010. So she's been sitting for around 10 years. The fuels system is a total disaster!! I drained what looked like dark maple syrup from the tank. I'm thinking about buying an ultra-sonic cleaner from Habor Freight for the carb work.
First - Won't crank
It took a while just to get her to crank ,(I have a tendency to go through the butt hole to work on the tonsils) I checked all of the safety switches (PTO, Seat, Brake) and found them to be good, then found the ignition wire "OFF" the solenoid. Plugged it in....Cranks great.
NEXT - No Spark
I have power to the coil when the key is on.
I pulled the flywheel expecting to check the points...ahhh...none there.
Found a series of very dirty magnets that I suspect make up the charging system.
I cleaned the magnets and put the flywheel back on....No spark.
Then my dog got out and I didn't get back to the shed. Hoping to get back out there today.
By firemanironman
I picked up a wheel horse and I am having trouble finding the connection for this wire. I have no spark and have searched for the placement of this wire within the distance of its length...any ideas?...can't seem to paste the picture....
By mmmmmdonuts
I was snowblowing the other day and got about half way through my driveway and all of a sudden my tractor died and I could not get it restarted. The first thing I noticed when it died was that the battery went down rapidly to about 7V but I think that had to do with my external alternator hooked up and not spinning but I could be wrong. I got the tractor back in the shed and could not get it turned over at all. The starter spins and everything seemed to move freely but I was not getting a spark. Changed the spark plug yesterday because it looked pretty gummed up and still nothing. This morning I was diving into the electrical system and got to the points where I was going to reset the timing and I realized that the points plunger does not move when I rotate the flywheel by hand.
I guess at this point I don't entirely know what I have to do. Is it an easy/worth it fix or does the whole engine need to come apart? Can I change it to a different type of ignition system? Any other thoughts to try? Repower?
Thanks,
Bob
