mmmmmdonuts
Tire Tube Weight limits
mmmmmdonuts
Is there a ply or weight limit to inner tire tubes? Or is it solely based on the tire rating? The reason I ask is if I put tubes in a 6 ply tire on a tractor with a FEL in the front will it be able support the weight? Tire would be a 16-6.5x8.
953 nut
No problem, the tire is doing the work and the tube is the same for all. Just be sure to keep the pressure up around 40 PSI.
mmmmmdonuts
Thank you. I wasn't sure if the tire was doing the work or if the tube had to bear any weight or not.
