Porangi
227-5 Transmission Belt Size
Porangi
Hi all,
Just a little bit of information regarding replacement drive belts for the 227-5 in the UK if you are not buying OEM that might help someone in the future.
The part number listed is 108427, which specs out as:
  • Top width: 13mm
  • Depth: 8mm
  • Outside Length: 2235mm = 87.99"
Sadly, a number of the first sites I found didn't specify that the 88" is the outside measurement so I having trusted their information and with the old belt still installed I just ordered A88s.
Anyway, as I'm sure you all know, belts are sold based on the internal measurement therefore you would require A86!
Actually now having spent some more time digging for information about the belt I have found sites specifying 88 as the outer diameter. including http://outdoorpowerinfo.com/, which seems like a pretty handy website.
Regards
Chris
gwest_ca
Belts can be very confusing.
If you need a B width belt that is 5/8" wide the industrial belts add 3" to the length.
A B85 would be 88" around the outside.
Garry
  • Similar Content
    • rustyedge1
      By rustyedge1
      Info needed.
      Going to put a oil drain on this engine next oil change and don't really know what I need to start. Trying to get parts ready before time.
      I don't know what size the existing plug is ( see photo ) 3/8" 1/4" ? Getting tired of taking the deck down every time I change oil. Any input welcome.
      Thanks in advance...
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
