1276Beast
1276 Transmission HELP Needed
1276Beast
I am currently towards the end of a 1276 restoration project, I just got everything back together and sent power to the transmission for the first time. Without the pump on and the gear in neutral, I can spin the axels by hand, one goes one way, the other, the other way, giving me indication that I don't have a differential problem. When I put power to it, everything appears to work as advertised, except when in gear I can stop the Axel from spinning with my hand, little to no resistance. I do have a bit of a rigging problem from worn linkage, but I can move the cam by hand to get it fully in gear. The tow gear in completely closed. Just flushed and filled with fluid. I have not changed the filter.
Any idea on why there seems to be no power in the axels??
953 nut
My guess would be that you opened the "Tow Valve" at some point and have not re-closed it.
Edited by 953 nut
WHX??
My guess is you have a choice resto happening there and we like it!
:handgestures-thumbupright: :WRS:
1276Beast
After reading through these forums, the first thing I checked was the Tow Valve. It was completely closed, I then opened it and reclosed it to verify. No joy.
WHX??
Given your obvious skills you checked all the "duh" factors like hub keys and such?? I am not a pro with a 1276 but bet my bottom dollar ther are guys here that are and they will be along.:)
Ed Kennell
Did it work OK before you flushed it?
1276Beast
Hub keys are good. I just replaced the axel seals and installed them the other day.
As as for the flush, it seemed to work the same before as it does now.
SPINJIM
When you grab the one axle by hand, does the other axle speed up ?   If 'yes', then I think that's the way the differential is supposed to work.  It is not a 'limited slip' differential on the 1276.  If you can stop both axles by hand at the same time, then you have some other problem.   I have a 1076, but have not taken the trans apart, so someone more experienced might correct me.
   Jim
Ed Kennell
So, I think you are saying this was not a working transmission when you got it and a flush and refill did not fix it.
Can we assume the input pulley key is OK and the pulley is not slipping on the input shaft.
What was in the unit when you drained it...oil or ATF?
What did you fill it with?
WHX??
In case you don't have it. Note the type of fluid and capacities in it. @achto has a 1076 with a Sunstrand maybe he can shed some light on your problem.
pfrederi
   Jim
Jim is on target here.  From your narrative it is unclear if you tried stopping both axles simultaneously or just held on to one....
Sarge
As long as the tires/wheels aren't loaded with weight - it should be pretty easy to stop one wheel on that trans model - it's an open differential and the early bevel gear design , like used on cars/trucks . Specifically , it's a simple 2-pinion of sorts and uses some pretty heavy bevel gears . In all the years I've had my 1277 , not one problem with that differential and I've pushed it well past reasonable limits - broken the frame mounting plate three times now with heavily loaded tires , lol . Biggest no-no with that style differential is to allow one tire to spin at high speed , then suddenly stop it on bare pavement or something - in a car , that results in an exploded diff gear in a hurry . Learned that lesson the hard way in my first car but the old Dodge was an easy fix .
The biggest thing you need to test is the strength of the Sundstrand pump and hydro motor that drives the transmission gears - when it's up to full hot temperature it should still easily spin the tires if it's in good shape . Don't be afraid to flush a couple rounds of oil through the trans along with a new filter each time to get any sludge out and dirt - keep it dead clean or trouble will result . Hopefully the intake screen isn't plugged or broken off - that spells death for some of the pump parts and @daveoman1966 has done some nice detailed posts on that model as to rebuilding the pump . It should be using regular ATF fluid , but some were changed later to motor oil so pay attention to what was in it , color and odor - ATF has a very distinct odor and easily detected , even when very old . The biggest issue with the Sundstrand was how previous owners took care of them , or lack thereof ...most never got their yearly oil change as specified in the manual .
Sarge
Achto
I was lucky with my trans and did not have to tear it apart so my knowledge is limited on these. All I did was change the fluid & filter & life was good for mine. I have been following this post hoping to learn something.
1276Beast
First off, thank you all for the posts. I have learned a lot from this site!
I got the wheels on today and fired her up. She ran flawlessly for about 15 minutes. The transmission issue I am having just seems to be a simple rigging problem as the cam seems to be warn. But none the less the transmission is strong as a bull!
Now I need to figure out why my carb started pissing fuel out of the intake, even after a rebuild.
Again, thank you all for the helpful insight. I'm happy to be apart of the Wheelhorse community and look to many happy years with my horse!
Jeremy
Edited by 1276Beast
WHX??
Your welcome from all of us  Jeremy, carb issue something as simple as a stuck float or other crap in ther? It happens after a rebuild...good luck!
Edited by WHX9
pfrederi
Make sure your float does not have gas in it
  • Similar Content
    • giant_g2
      By giant_g2
    • Thatoneguy
      By Thatoneguy
      So I washed my rear end and sundstrand 90-1136 and now the by pass valves leaks when I screw it in past a certain point.  If I screw it all the way in I can sit there and watch the fluid start seeping past it.   I changed the o-ring with an R-04 i believe is what it was.   Do these require some sort of thread sealer? There was nothing on it when I took it out, and when I used the valve to push the tractor in my shop it worked fine and has never leaked. Any ideas would be wonderful!
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
