Andrew D. 23 #1 Posted March 23, 2017 (edited) I recently took on welding up the rust holes on a wheel horse 244-H 38in. mower deck, i quickly found out it was way worse than i thought and all in all completely junk so i took down the model number and called a local outdoor equipment place and they couldn't find anything on both the tractor or the mower using the model numbers. so what do i have? and if anyone knows where to find a deck in the southwest Mi. area, just the shell would be fine, i'm in the market . Edited March 23, 2017 by Andrew D. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,158 #2 Posted March 23, 2017 Here is the tractor Here is the mower deck A search of the Library (files) should bring up more results. Using the 22-14OE01 model number works the best. 14=engine hp O=Onan engine E-Eaton hydro 01 are both numbers. Don't get the O's and 0's mixed up and include the - Garry Share this post Link to post Share on other sites
WHX?? 49,599 #3 Posted March 23, 2017 I might have a deck for ya Andrew. I believe I have a 244 parts tractor and if I remember right the deck was in fairly decent shape. PM me if interested. Share this post Link to post Share on other sites
WHX?? 49,599 #4 Posted March 24, 2017 Keep in mind Andy the deck I have is a 42 but should fit up. You guys have to check out the new "twist" on this motor...wt ! BTW the motor is yours too if you want it guy. I will never use it but might be ok for parts? It does spin. I pretty much just saved it for possible hydro parts. Share this post Link to post Share on other sites
