WVHillbilly520H 10,374 #26 Posted March 23, 2017 (edited) Duke, I have no experience with the Deestone brand others on here have stated not only narrower width but shorter height than what they are designated as, Those OTR LAWN TRAC R1 I mentioned above, are described as 10.85" section width and 22.8" tall like the Carlisle, I would assume that once mounted the tires should "balloon" a small amount, I went with the Nanco tires because before I bought the anniversary 520 new in 1998 I bought a pair new for my old CC 106, I kept them put them on my dad's CC 1200 and 19 years they are still not weather checked or dry rotted (but he never mowed with it only gardening, snow removal, and firewood gathering) so that may have something to do with it, also my F.I.L. has a Roper setting out his barn with bought new 12 year old Carlisle AGs that are dry rotted severely but was a mower only, and my used Nankangs were cracked before I ever mounted them but I run tubes with fluid so that wasn't an issue, so I did a little research with pics for everyone to scour over, hope this helps out, Jeff. Edited March 24, 2017 by WVHillbilly520H 4 Share this post Link to post Share on other sites
WHX?? 49,484 #27 Posted March 24, 2017 Excellent info ther Billy, I just got a pair of Tru-Powers, 23-850-12, for a build and was rather disappointed by the width and perceived? beefyness. Probably should have went with 10.50 for the wider tread and "balloon" look & performance? I am putting these on a tractor just for some glamor shots but eventually to put them on my 1257 for plowing duty. Pics to follow 2 Share this post Link to post Share on other sites
HorseFixer 2,012 #28 Posted March 24, 2017 Well just to nip this in the BUD I sent the Ebay Seller a message advising him in advance what I have found out and what I expect. I encluded a picture that WVHillbilly520H included and you can see his reply. Documentation is better than conversation in this case voicing my concerns well before I get the product gives Ebay documentation to go on. As you can see by the Auction they are covered by EBAY PROTECTION. If they are not 10.5" Wide back in the box they go and I will recieve my MOOLA BACK! (PERIOD......) Jeff I appreciate your work on this. I will Ck into the OTR's Thanks again ~DUKE 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #29 Posted March 24, 2017 10 hours ago, HorseFixer said: I encluded a picture that WVHillbilly520H included and you can see his reply. Jeff I appreciate your work on this. I will Ck into the OTR's Thanks again ~DUKE I believe that was preferdi's pic but I'm sure I overloaded the senses with my pictures, and FYI the OTR brand tires are Kubota first choice installed tires from the factory on the their L&G machines, Jeff. 1 Share this post Link to post Share on other sites
pfrederi 17,973 #30 Posted March 26, 2017 On 3/24/2017 at 7:43 AM, WVHillbilly520H said: I believe that was preferdi's pic but I'm sure I overloaded the senses with my pictures, and FYI the OTR brand tires are Kubota first choice installed tires from the factory on the their L&G machines, Jeff. Yes it was my picture. I went today and took shots of the side walls Little hard to see (The tractors are hibernating) try enlarging them. Both are 10.50 (deestone has wheel weight Carlisle no weight just my foot. Another comparison shot clean tire is Deeston 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #31 Posted March 26, 2017 Sorry I spelled your name wrong, but I like to give credit where it's due, Jeff. 1 Share this post Link to post Share on other sites
ericj 1,578 #32 Posted March 28, 2017 I have Carlise 23x10.50x12 and Deestone's and Nanco. the Carlisle's are definitely the widest. I have a set of either Nanco's or Destone on 8.5 rims, they look like balloons. On the other hand the same tires on 7.5 rims only measure 23x9.5x12. They look good on the 416's and C series and work real good on them. I just remembered when I installed the Nanco or Deestone, I believe they are Nanco's I had to install tubes in the tires becuase they wouldn't blow out and seat on the rims, in fact when the tire store was mounting them they had to install a tube for free to get the tire to mount. A year later the other tire went flat and I had to pay to have the tube put in. the 73 16 AUTO withe the Nanco's on 8.5 rims is in it's winter storage inside the enclosed trailer and not sure if I can get a measure on them. My vote for a 520 or any 8.5 rim would be the Carlisle's eric j 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #33 Posted March 28, 2017 @ericj, a couple pictures would be worth a 1000 words for comparison sake, Jeff. Share this post Link to post Share on other sites
HorseFixer 2,012 #34 Posted March 28, 2017 (edited) On 3/26/2017 at 2:58 PM, pfrederi said: Yes it was my picture. I went today and took shots of the side walls Little hard to see (The tractors are hibernating) try enlarging them. Both are 10.50 (deestone has wheel weight Carlisle no weight just my foot. Another comparison shot clean tire is Deestone 11 hours ago, WVHillbilly520H said: @ericj, a couple pictures would be worth a 1000 words for comparison sake, Jeff. Sorry pfrederi thought it was WVhillbilly520H picture anyways I appreciate all of you guys help! Yeah WVHillbilly520H How about these Pics Below! They are worth a thousand Words Too! ANNOUNCEMENT! The tires came today and all I can say is the Seller slipped Ole DUKE the GREEN WEENIE! If it weren't for NO LUCK I would have none at all The Deestones are NARROWER than the STOCK TIRES! Here are some PICS. I have Filed a return and talked to FLEE Bay on the Phone Today and told the Guy I wanted my Mooo La Refunded! Edited March 28, 2017 by HorseFixer 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #35 Posted March 28, 2017 Duke, for about the same green try a pair of these, or step up to the 24x12-12 Ags of the cheaper brands that's what I was originally going to do but ya know how things go, and those turf tires in your pics aren't the original Dicos what brand are they Carlisle? Turf Saver? Jeff. 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #36 Posted March 29, 2017 Jeff they are DEESTONES! Is the OTR Lawn Trac;s Are they as wide or wider than the Carlisle? Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #37 Posted March 29, 2017 The OTR, According to the literature 10.85 section width and 22.8 tall with the more aggressive lugs like the Firestone, Jeff. Share this post Link to post Share on other sites
fast88pu 3,324 #38 Posted March 29, 2017 My 312 with 26x12x12 on 10" wide custom rims and fender pan raised 1" 3 Share this post Link to post Share on other sites
