tommyg 154 #1 Posted March 20, 2017 Anyone have any experience with one of these? I'm thinking of investing in one to make it easier to pressure wash the underside of my deck and sharpen the blades. 6 Share this post Link to post Share on other sites
Ed Kennell 40,237 #2 Posted March 20, 2017 Where do the fluids go? 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #3 Posted March 20, 2017 I have never seen anything like that. Do you have any more pictures? 1 Share this post Link to post Share on other sites
953 nut 57,473 #4 Posted March 21, 2017 Don't know that I would want one myself, rather lift the front, but here is a link to it. https://www.amazon.com/Bradley-Cliplift-Magnum-Hydraulic-MJ4000/dp/B018WIWBJO Share this post Link to post Share on other sites
tommyg 154 #5 Posted March 21, 2017 By lifting in the front, you really can't get underneath that well because the jack is in the way. This method gives you a clear shot at everything in my opinion. On 3/20/2017 at 11:13 PM, Ed Kennell said: Where do the fluids go? The actual foot pump is on the opposite side. You can't really see it in the picture. Share this post Link to post Share on other sites
Ed Kennell 40,237 #6 Posted March 21, 2017 Yep, I got that tommy. I was referring to the fluids in the tractor.....engine oil, gasoline, and transmission fluid. 4 Share this post Link to post Share on other sites
pfrederi 18,279 #7 Posted March 21, 2017 On 3/20/2017 at 11:13 PM, Ed Kennell said: Where do the fluids go? If I used it on most of my tractors there would be puddles of oil, ATF and gas on the floor. 2 Share this post Link to post Share on other sites
SPINJIM 1,981 #8 Posted March 21, 2017 (edited) Seems like it would be hard on the front axle and front wheel spindles. And it's a lot of lateral pressure on wheel bearings that are designed to take vertical forces, especially considering the weight of twin engines and hydraulic transmissions. Edited March 21, 2017 by SPINJIM 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #9 Posted March 22, 2017 I think I'd like it for blade & zerk access but not fluid changes. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #10 Posted March 22, 2017 Where do the fluids go when you lift the front of a mower? I don't see this any different, other than you may be lifting it a bit higher with this lift. Fluids will go to the lower part of the area they're stored in regardless where that part is, back or side. The couple of problems I see is introducing forces on the one remaining tire on the floor, and maybe limited access to the bottom most blade as it's closer to the floor. Plus the strap that goes around the tire looks a bit small and not too heavy duty. 1 Share this post Link to post Share on other sites
Ed Kennell 40,237 #11 Posted March 22, 2017 I have always removed my decks and blades for maintenance. So I don't have a need to work under my tractors. I lift it from the front with a hoist if I want to totally drain a tranny. I would never work under a load suspended by a hoist or jack until it was properly blocked. The thin pipe safety rod shown on this device looks susceptible to bending under load. I would feel much better if a 2" square tube was used instead. Share this post Link to post Share on other sites
Sarge 3,464 #12 Posted March 22, 2017 Here's some better views of their design , albeit a lighter/cheaper model in it's ratings... https://www.amazon.com/Bradley-Cliplift-Hydraulic-Mower-MJ3000/dp/B00HANVDV0/ref=pd_sbs_86_1/162-9368595-9118518?_encoding=UTF8&psc=1&refRID=2J9JGS0DNFZF8VKJF1DW Not sure I'd want to pick up any serious garden tractor with those things - at full lift height you'd risk possibly turning it over . Not a bad setup for lighter/smaller zero turn units , though... Sarge Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #13 Posted March 22, 2017 For those who are interested, here is a video of it in use. From the reviews, 54 inch decks and larger, it may not work too good, if at all since the deck sticks out further from the tires. Share this post Link to post Share on other sites
tommyg 154 #14 Posted March 22, 2017 (edited) On 3/22/2017 at 2:12 PM, T-Mo said: From the reviews, 54 inch decks and larger, it may not work too good, if at all since the deck sticks out further from the tires. T-Mo, that was the one thing I was worried about. I retrofitted my d180 with a 60" deck. I was afraid it would stick out too far. I did a chat session the the folks at Bradley Mower. This is what they said... "It (the deck) may rest on the ground. We have not had any reports of damage. I have seen that it does rest at those size decks. We have used them in our local shop with customers who had decks that size with no problem." Edited March 22, 2017 by tommyg Share this post Link to post Share on other sites
