cafoose
1988 520-HC will not start when hot
cafoose
My 1988 520-HC (I did get lots of snow that's an old picture) :lol: starts up great at first but after running it awhile it will not start back up. It cranks over fine it just does not start. I sprayed starting fluid in the carburetor and that does not help. When I let it sit for a few hours and come back to it, it starts up fine. Today I was cleaning up some snow and it worked great while it was running. I ran it out of gas earlier today :angry-screaming:  and when I filled it up it did not start until a few hours later. :angry-banghead: I put it back in the shed when I was finished with it and when I shut it off I tried starting it back up in a couple minutes and it did not even attempt to fire up. :confusion-confused:Does anyone have any ideas what might be wrong with it? :help:
ericj
ignition module, when it shuts off get a meter and put it on the negative side of the coil and the negative battery post, spin the motor over by hand and you should see the voltage go from 12 volts to 1 1/2 volts and back to 12 volts if it doesn't then it is it is bad if it does then you have another problem.
I see your in york pm me and load it up and bring it over and i'll help you figure it out
eric j
Edited by ericj
cafoose
Don't you think if it was the ignition module it would quit running on its own? :confusion-shrug:It will continue to run as long as I don't shut it off but when I do shut it off it doesn't start until after it sits for a long time.
cleat
You will need to check out the power to the coil and verify you have +12 Volts when the key is on and also in crank position.
If not then start bactracking to figure out why.
If so then verify the negative side is pulsing when cranking to verify the module.
If negative side stays constant at ground or +12 volts then the module is likely bad.
If it is pulsing and you have 12 volts on the positive side of the coil then the only thing left is the coil itself.
Cleat
elliot ness
I have had that problem before and it was the coil. changed the coil and presto all better.:twocents-02cents:
ericj
the onan service manual does a real good job telling how to trouble shoot almost any thing wrong with an onan motor. I'm sure it's on here for down load if nit I can email it to you.
eric j
cafoose
This is directly out of the Onan service manual. I am going to run it until it is warmed up and go through these steps.
1. Check all electrical connections to be sure they are
clean and tight. If all connections are good and
wiring is intact, go to step2 .
2. Pull spark plug wires off spark plugs and remove
spark plugs. Connect an approved spark tester to
each of the spark plug wires and ground them away
from spark plug hole. Turn key on and crank engine
over for 5 seconds while watching for spark. If a
spark occurs regularly, the problem is not in the
ignition system. If no spark occurs, go to step 3.
never put jumper leads to the negative coil terminal this
will cause failure of the electronic ignition module.
3. Connect a jumper lead directly from the positive
battery terminal to the positive (+) coil terminal
(smaller diameter of the two threaded posts). Crank
engine over while watching for spark. If spark
occurs, the problem is in the low oil pressure cut out
switch (if equipped) or related wiring, the lubricating
system (low oil pressure), or in the other circuitry
bringing voltage to the coil. if no spark occurs, go to
step 4.
4. Refer to IGNITION COIL section to test coil for
proper resistance. If coil checks out good, go to
step 5.
5. Connect positive side of voltmeter to negative (-)
coil terminal (larger diameter of the two threaded
posts) and negative side of voltmeter to engine
ground. Turn key on and rotate flywheel slowly by
hand while observing voltmeter. Voltage should
switch between battery voltage and 1-1.5 for each
revolution. If voltage does not switch properly,
replace ignition module.
Never put B+ lead to the coil negative terminal
This will cause failure of the electronic ignition module.
6. Install spark plugs and wires. If ignition module is
being replaced, be sure to connect red lead from
new ignition module to positive(+ ) terminal of coil,
black lead from module to negative (-) terminal of
coil.
IGNITION COIL
To test primary and secondary windings within the
ignition coil first make sure the ignition power is off and
coil is at room temperature of 70°F (21 "C).
1. Use a Simpson 260 VOM or equivalent.
2. Place a black lead on negative (-) coil terminal and
red lead to positive (+) coil terminal. Primary
resistance should read between 2.90-3.60 ohms.
3. Change resistance setting on ohmmeter. Place
ohmmeter leads inside of spark plug cable holes
(Figure 3). Secondary resistance should read
between 14,500 - 19,800 ohms.
4. If either of the above resistances are not within specifications,
replace the coil.
Edited by cafoose
cafoose
I left it run for 10 or 15 minutes and it starts right back up. It seems to be fine now. I heard Onans are temperamental  :deadhorse:  and expensive. I'm thinking of a repower and trading or selling the Onan for a Kohler or Honda. :techie-eureka:How many modifications to fit a K-341 16hp and is it powerful enough?
Edited by cafoose
  • Similar Content
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
      My troubleshooting so far:
      Fuel:
      • stabil/87 and clean
      • good flow before and after pump
      • carb clean, recently rebuilt, float level correctly set
      Compression:
      •good? - blows finger off spark plug hole
      •good turnover but doesn’t fire off
      •piston and cylinders move freely
      •valve lash set .008 intake .018 exhaust
      •breather assembly correct and recently serviced with new gaskets and filter
      •head gasket not broken, head bolts tight, some carbon on head
      Spark:
      •no spark
      •all electrical/ignition components were replaced 1 year ago except voltage regulator
      •no loose connections, no grounding connections
      •inspected and applied graphite to starter shaft
      •changed plug
      •12v to coil good
      •cleaned points, points wire has continuity
      •condenser ground good
      •swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
      •points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
      What else should I check/do?
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
    • Brockport Bill
      By Brockport Bill
      520 HC Tractor For Sale: please see photos; Just 630 hours on meter. Powerful Onan 20 HP motor. Hydro transmission, Hydro lift. This HC was limited 2 year production, top of the line Wheel Horse commercial model - including swept front axle. Cleaned and serviced, new Carburetor, new plugs, new engine oil, new tranny oil, new battery, new decals, new foot treads, rebuilt hydro lift cylinder, zerk fittings all lubed, tires hold air, headlight rims. Seat adjust feature. Cash pick up as is, Hudson River Valley, Poughkeepsie, NY area. Tractor only, priced at $1,550. Also available as option: Rehabbed 48 inch side discharge mower deck, professionally sandblasted shell plus lift carriage assembly to remove rust and paint; then newly primed and painted. Plus new hardware. Blades cleaned, sharpened and balanced. Mower deck available at $ 440.  Please send p.m. for questions or info?
    • SPINJIM
      By SPINJIM
      1992, Wheel Horse 520-H.   Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts.  Seat is like new.  Front tires are new.  All tires hold air.  Some repainting, but didn't need much; was stored indoors.  New decals.  Other new parts.
      Has swept front axle and Variable Ratio Steering.  Belt cover ventilated to cool back cylinder.  Rear wheel weights are 55 lbs. each.
