Similar Content
By Joe Reese
60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great Joe Reese
By BrianKoch
Gentlemen,
I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
My troubleshooting so far:
Fuel:
• stabil/87 and clean
• good flow before and after pump
• carb clean, recently rebuilt, float level correctly set
Compression:
•good? - blows finger off spark plug hole
•good turnover but doesn’t fire off
•piston and cylinders move freely
•valve lash set .008 intake .018 exhaust
•breather assembly correct and recently serviced with new gaskets and filter
•head gasket not broken, head bolts tight, some carbon on head
Spark:
•no spark
•all electrical/ignition components were replaced 1 year ago except voltage regulator
•no loose connections, no grounding connections
•inspected and applied graphite to starter shaft
•changed plug
•12v to coil good
•cleaned points, points wire has continuity
•condenser ground good
•swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
•points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
What else should I check/do?
By lsc1257
I have a 1996 520H Wheel Horse for sale. The tractor has just over 800 hours on it. It comes with a 48 inch deck. The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago. This 520-H has the swept front axle so it can handle a 60 inch deck. I just replaced the battery and the deck belt this summer. The engine is a 20HP Onan and it starts right up but requires the full choke. The transmission is an Eaton 1100-062, hydrostatic. The deck is in rough shape but the spindles appear to be in good working order. The right rear tire has some cracking. The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck. Also included is a new PTO belt and several miscellaneous deck wheels and rollers. Additional pictures available upon request. Asking $500.
By Joe Warren
Wheel Horse
Service Tool Kit
Onan Industrial Engines
ON-420-0556
Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
$129 plus shipping cost.
Message me if you are interested in purchasing. Thank you. Joe
By Brockport Bill
520 HC Tractor For Sale: please see photos; Just 630 hours on meter. Powerful Onan 20 HP motor. Hydro transmission, Hydro lift. This HC was limited 2 year production, top of the line Wheel Horse commercial model - including swept front axle. Cleaned and serviced, new Carburetor, new plugs, new engine oil, new tranny oil, new battery, new decals, new foot treads, rebuilt hydro lift cylinder, zerk fittings all lubed, tires hold air, headlight rims. Seat adjust feature. Cash pick up as is, Hudson River Valley, Poughkeepsie, NY area. Tractor only, priced at $1,550. Also available as option: Rehabbed 48 inch side discharge mower deck, professionally sandblasted shell plus lift carriage assembly to remove rust and paint; then newly primed and painted. Plus new hardware. Blades cleaned, sharpened and balanced. Mower deck available at $ 440. Please send p.m. for questions or info?
