HamptonT
Tine Wear
HamptonT
Are these good tines or worn tines? In your opinion? Thanks
WHX??
Not too shabby IHO... I would think you will get some use out of them.
kasey54
Id say they are about 3/4 of perfect. Good life left.
pfrederi
They are good.  When the end is almost pointed instead of flat then they are shot.
ACman
I don't know if it's possible because of warpage but you might be able to have the edges hard surfaced welded . This could prolong the life of the tines (I herd they're expensive) If you're worried about wear .
 Maybe @TIGman or @Sarge could chime in with their welding experience ?
Sarge
For the cost of hard surface rod , I'd just cut off a section of the ends and weld on some tougher steel . From what I've seen the tines are just made from regular 60XXpsi variety...going to one of the spring steels would help.
Sarge
