953 nut 57,513 #1 Posted March 10, 2017 Krusin C's List and thought I'd pass this along. 8 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #2 Posted March 10, 2017 I think it is a "what the What " or Ed Kendall's "Low Rider " on drugs. 3 Share this post Link to post Share on other sites
WHX?? 50,512 #3 Posted March 10, 2017 I'd take off the fronts.... prolly never be on the ground anyway! 3 Share this post Link to post Share on other sites
Ed Kennell 40,254 #4 Posted March 10, 2017 Think I would cut the hood off at the stack and lower it down to the frame. Let that power plant stick up above the hood. The Low Rider would need a overdose of steroids to run with that big dog Jim. Will you be bringing it to the show Richard? 4 Share this post Link to post Share on other sites
squonk 42,306 #5 Posted March 10, 2017 3 minutes ago, Ed Kennell said: Think I would cut the hood off at the stack and lower it down to the frame. Let that power plant stick up above the hood. The Low Rider would need a overdose of steroids to run with that big dog Jim. Will you be bringing it to the show Richard? Yes! It would look like a red "Munster Mobile"! 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,200 #6 Posted March 10, 2017 Some questions to expect from a typical CL add response caller on this ad: Will it power a 60" deck? Do you think it has enough power to run a tiller? Do you think a standard long frame front blade will fit? Should I use chains? Does it smoke? Will you take $100? 9 Share this post Link to post Share on other sites
953 nut 57,513 #7 Posted March 10, 2017 24 minutes ago, Ed Kennell said: Will you be bringing it to the show Richard? If you want to buy it I will haul it for you! Seller is asking $ 2,500 without the engine. Hauling it would be complementary. 3 Share this post Link to post Share on other sites
AMC RULES 37,144 #8 Posted March 10, 2017 17 minutes ago, 953 nut said: Seller is asking $ 2,500 without the engine. I'm thinking...the big pipe you see on that ... must be made outta glass. 2 Share this post Link to post Share on other sites
Ed Kennell 40,254 #9 Posted March 10, 2017 Thanks for the hauling offer Richard, but I'll have to pass. I never pay over $200 for a non-running horse. 4 Share this post Link to post Share on other sites
petes 150 #10 Posted March 10, 2017 Speaking of Hot Rods 10 Share this post Link to post Share on other sites
KC9KAS 4,743 #11 Posted March 11, 2017 17 hours ago, 953 nut said: Krusin C's List and thought I'd pass this along. Sure could mow your lawn quick with that.....as long as you had a BIG, treeless yard! 1 Share this post Link to post Share on other sites
