osubrutus1
42" mower deck rebuild
osubrutus1
what are some good sites to purch parts to rebuild my mower deck please?
N3PUY
I got bearings from "USA Bearings and Belts".
Kurt-NEPA
I did the same.  The bearings are working just fine.  I bought the rubber shielded version and pulled out the inboard shield to permit fresh grease to enter.
N3PUY
But remember .... too much grease can "pop" the remaining seal out of the bearing :(
Kurt-NEPA
Yep, but leaving the seal in place means no fresh grease gets to the bearing.  Moderation is the key.
daveoman1966
What kind / type of spindles are on your 42" deck?  There are 3 or more styles.
I have lots of parts to rebuild but need toknow your needs first.
Mthrtrkr
Curious to know where to find replacement parts for my Rd as well
can whlvr
one word of advice,dont use cheap bearings,get good ones,its a lot of work to rebuild just to save a couple of bucks,try to stay away from china crap
Spoiler
cleat
I rebuilt a chaincase on a Fairly high end Cub Cadet snowblower attachment this winter.
The chain broke for some reason.
This chain case has 4 ball bearings. All of them simply said "China" on the rubber seals.
All seals are installed on these bearings even though the chain case is full of grease.
Sad to see Cub Cadet using such cheap bearings (although they were in great shape still).
I do realize that machine was likely made by MTD but still.
That was a fairly expensive machine purchased at a Cub dealer. I can't remember the model number but it is a shaft drive hydro with power steering
and I think around 24 HP.
Maybe the roller chain was Chinese as well and that is why it broke.
Rant ended, Chinese bearings are used by OEM builders in the US now apparently.
I agree though, use good bearings, price difference is really not that great.
Cleat
