Elkskin's mower junkyard 1,117 #26 Posted March 4, 2017 2 hours ago, aHorseofCourse said: There's nothing like a freshly painted horse! It's so much work tho, I dread doing it every time. i done a sears suburban a few years ago i know how that is lol Share this post Link to post Share on other sites
aHorseofCourse 261 #27 Posted March 5, 2017 Got the lift on today. It works great. I still can't believe I actually found one of these. Only down side is it doesn't lift my blade up nearly as high with the solid down pressure bar on. I had to put the standard mower linkage with the chain on. I never needed down pressure with snow anyway so this is no big deal. Difference in the clutch linkage. The plate on the front of the battery compartment needs to be cut. The original kit came with a new plate. 3 2 Share this post Link to post Share on other sites
aHorseofCourse 261 #28 Posted March 18, 2017 (edited) Got my gauges mounted. Had to patch up the cut-outs where the dial-a-height was. Also put the switch for the lift in the wrong spot and had to patch that and re drill. Turned out pretty good considering it's thin metal and I have a stick welder. Everything needs sanded and painted yet. The tiny tach is screwed to a piece of flat stock then welded to the dash. Edited March 18, 2017 by aHorseofCourse 1 Share this post Link to post Share on other sites
aHorseofCourse 261 #29 Posted July 7, 2017 Ok so work has picked up and the kids keep me busy, but I did make a bit of progress over the last month or so. Found a front swept axle assembly with reduction for the swap. Got everything shimmed and painted. New tires I found at the big show. Engine is ready, tractor will go under the knife shortly! Needed new bearings and races. The old ones were rusted pretty bad. Put a .004 shim in the bearing block and .001 on each side of the pinion gear to tighten everything up. 16 7.50 8 OTR Lawn Trac. 3 Share this post Link to post Share on other sites
aHorseofCourse 261 #30 Posted August 21, 2017 Work has been slow and I got a lot done lately. It's almost finished now. Little Kohler removed My supervisor checking my work All cleaned and painted New vs old. I can't believe how heavy duty that swept axle setup is. Shorter reduction rock shaft vs stock. Still had to grind a little off so it would clear the steering gear. welded 1/2" thick plate under the dash so I could use a flange ball bearing instead of the cheap stock unit. steering and axle done Finally set her in her new home 2 7 Share this post Link to post Share on other sites
Aldon 4,828 #31 Posted August 21, 2017 Looks great ! 1 Share this post Link to post Share on other sites
mike416 14 #32 Posted August 21, 2017 Looks great friend! I really like the bearing upgrade on the steering shaft. I recently modified my 314-8 to the swept forward front axle. The red accents on your engine are a great touch as well. Keep up the great work!!! 1 Share this post Link to post Share on other sites
19richie66 17,578 #33 Posted August 21, 2017 Looks great. Bet it lacks no power now! 1 Share this post Link to post Share on other sites
aHorseofCourse 261 #34 Posted August 21, 2017 Thanks for the kind words fellas. Feels good to finally be putting it back together. Share this post Link to post Share on other sites
aHorseofCourse 261 #35 Posted August 21, 2017 More pics. Replaced both pto bearings New tires. Found the elusive 8.5" rear wheels on flea bay earlier this year. Tires are 8.5 vs 10.5 wide. 10's are about an inch taller too for some reason. New dash Getting there. Belt guard from an 1848 Custom exhaust work. I love the look of the old iron pipe exhaust, but there aren't any good fittings for a collector. Decided to make one, 2 90's cut off with a piece of sheet metal between. Welds on the cast iron are ruff to say the least but seem to be holding. 3 Share this post Link to post Share on other sites
aHorseofCourse 261 #36 Posted August 21, 2017 Just about done. Still a few odds and ends. 4 7 Share this post Link to post Share on other sites
ACman 7,630 #37 Posted August 21, 2017 (edited) That's one sweet looking horse ! Edited August 21, 2017 by ACman 1 1 Share this post Link to post Share on other sites
clueless 3,113 #38 Posted August 22, 2017 Damn fine work sir. I'd be interested in the 8 hp kohler, if your thinking of selling it. Chris. 2 Share this post Link to post Share on other sites
aHorseofCourse 261 #39 Posted August 22, 2017 8 minutes ago, clueless said: Damn fine work sir. I'd be interested in the 8 hp kohler, if your thinking of selling it. Chris. I am thinking of using it to power a log splitter down the road. I'll let you know if I ever part with it. Share this post Link to post Share on other sites
PeacemakerJack 10,743 #40 Posted January 12, 2018 Great work!!! Lots of custom touches yet still keeps an original “feel”. I think it is totally great that you had “the inspector” out there with you in the shop. This is a fine machine that is built precise enough to be a show queen but durable enough to be used daily. All around—sweet! 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #41 Posted January 12, 2018 I just reread this thread , you did an amazing amount of work on this project all I can say is . 4 Share this post Link to post Share on other sites
mrc 875 #42 Posted January 12, 2018 love the exhaust work! tractor looks great. nice job. mike in mass. 1 Share this post Link to post Share on other sites
littleredrider 409 #43 Posted January 12, 2018 Awesome work, I’m jealous!! I can’t get anything done to mine lol. Exhaust setup is nice, curious why didn’t run duals? Make that twin sound mean! I put two hot dog type mufflers on the 518 repower and sounds like a harley. 1 Share this post Link to post Share on other sites
aHorseofCourse 261 #44 Posted January 13, 2018 Thanks for the kind words everyone. Lots of work but I'm happy with how it turned out. 11 hours ago, littleredrider said: Awesome work, I’m jealous!! I can’t get anything done to mine lol. Exhaust setup is nice, curious why didn’t run duals? Make that twin sound mean! I put two hot dog type mufflers on the 518 repower and sounds like a harley. The thought crossed my mind but I wanted more of a tractor look than hot rod, plus I didn't want it too loud and have the neighbors throwing things at me . It's still pretty loud, these briggs flat twins are beasts! 2 Share this post Link to post Share on other sites
aHorseofCourse 261 #45 Posted January 13, 2018 Figured I'd throw my latest pics up here. Added front wheel weights, 2" receiver hitch, led tail lights, and a ROPS off a mini excavator. Also got the belt guard painted and lengthened the plow frame for the swept axle. The ROPS not only allowed me to mount the lights nice and high but also adds 85lbs of rear counterweight. Next up for it is electric pto clutch and then a full time hydraulic setup. Want hyd lift and eventually (like years away) a loader setup. Only difference is the pump and tank will stay on permanently. These weights are a dime a dozen and cheap so I figured I'd take a chance they'd fit. Of course they didn't and the hole had to be made bigger to accommodate the bearing housing of the wheel. Carbide tip hole saw and a few whacks with the chisel later and they fit. I think they would work on the standard 8" wheels with no mods. Lots of spaghetti Switch for front fog, rear fog, and strobe. One empty for future whatever and two direction switches for future electric chute mods on the single stage. 1 5 Share this post Link to post Share on other sites
PeacemakerJack 10,743 #46 Posted January 13, 2018 Thanks for sharing the updated photos! This is a great machine and your hard work has paid off. If you have someone around who can video for you, you’ll have to get a shot of it in action and post it here. 2 Share this post Link to post Share on other sites
aHorseofCourse 261 #47 Posted January 14, 2018 19 hours ago, PeacemakerJack said: Thanks for sharing the updated photos! This is a great machine and your hard work has paid off. If you have someone around who can video for you, you’ll have to get a shot of it in action and post it here. I'll get a video of it sometime. I was hoping to test the blower out and see what the big Briggs can do but we haven't had much here yet. 1 Share this post Link to post Share on other sites
ebinmaine 70,789 #48 Posted January 15, 2018 On 1/13/2018 at 12:04 AM, PeacemakerJack said: Thanks for sharing the updated photos! This is a great machine and your hard work has paid off. If you have someone around who can video for you, you’ll have to get a shot of it in action and post it here. I'll second that! On 1/13/2018 at 7:55 PM, aHorseofCourse said: I'll get a video of it sometime. I was hoping to test the blower out and see what the big Briggs can do but we haven't had much here yet. Wonderful rig you have there. Like many others on this site, yours is an inspiration to work on my own. Looking forward to a video when you can. 1 Share this post Link to post Share on other sites
