Indianajohn
Repair fuel sender?
Indianajohn
The fuel gauge on my new (to me) 520H isn't working. The gauge is getting power and ground. If I ground the brown wire at the sending unit, I get FSD on the gauge needle, so I know the gauge itself is okay. I pulled the sending unit and get nothing from the white wire to ground no matter where the float is positioned (infinite ohms). If I test from where the white wire is soldered on over to where the bare wire wraps around to the first winding of the rheostat, I get continuity. But if I go from the white wire to the actual first wrap on the rheostat, I get nothing again. So it appears that the bare wire is broken between the where the white wire is soldered on and the first wrap on the rheostat. Of course it is on the back side where I can't get to it. Has anyone ever taken one of these apart and successfully repaired it? It appears that you would have to drill out the brass rivets that hold the restart part to the metal brackets, solder the broken wire, and replace the rivets with small bolts or something similar. I figure I have nothing to lose by trying. It's not working now anyway. My guess is that these are very expensive to replace. None on eBay right now. Any thoughts, encouragement, or otherwise?
Thanks!
tbarnhart
Have at it. Your approach sounds like it would work, although that tiny wire they make those senders out of is a pain to repair. Like you said, you don't have much to lose. At our shop, we call it the "rotten egg theory", as in, "you can't ruin a rotten egg". If it's already no good, can't really make it much worse.
woodchuckfarmer
Member Wheel bearing did a rebuild on a 520 and I think he used one from a car . Not real sure,  but its worth looking for.
Indianajohn
Thought I would finally post an update on this project. I was able to get the sending unit apart and repair the broken rheostat wire inside by soldering. Wasn't easy, but it does work after a fashion now. Since I ended up having to shorten the wire by a couple of turns before soldering it, the gauge won't go full scale anymore. But at least it does work well enough to satisfy me. I'm more interested in knowing when I'm about to run out of gas than when the tank is full. I was able to carefully grind the heads off the rivets to separate the housing and get to the rheostat to repair it. I then used very short 10-32 screws and nuts to reassemble it. So I would call the repair a qualified success. As usual, YMMV.
evanloock
Since the earlier 520-H and 520-HC models used gauges (including the fuel gauge) sourced from Stewart-Warner, I bet the fuel gauge sending unit was as well.  I have seen on their website that they have a myriad of sending units available.  I bet one might just be correct for the 520 tank.
Edited by evanloock
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
