oliver2-44 10,341 #51 Posted December 26, 2024 1961 Suburban 551 Hood Sand Parts Drawing and some notes. On 4/4/2017 at 6:27 AM, T-Mo said: Also, I'm still playing around with the model of my 551. I still need to measure some things, a lot of things.... @T-Mo Here the 551 Hood /stand drawing to help you along. The 1/4 x 1-3/4 x 8-5/8 Flat Bar welds to the left side of the frame. it sits 1/2' inward and mounts directly against the round foot rest bar. The 1/4 x 1-1/4 x 1-3/4 (2 required) They mount with an edge directly inline with the outer edge of the right side of the frame. One welds directly against the right round foot rest bar. The other one welds to the frame 8-3/4 from the right foot rest bar. This should result in the 2 tab having a 9" wide outside to outside dimension. The hoods stand mounts to the outside of these 2 tabs. The battery holder bar installs with 2 long 1/4" bolts that extend back to the 1/4" holes in the left side hood stand frame mount bar. WH 1961 551 Suburban Hood Stand Drawing.pdf Share this post Link to post Share on other sites
oliver2-44 10,341 #52 Posted December 26, 2024 Saw this drawing and though I'd add it here to have some drawing all in one place Stormin Normin created this drawing to build a Slot Hitch. Share this post Link to post Share on other sites
