Kavint76 56 #1 Posted February 14, 2017 I haven't been on for awhile but i got my starter coils rewraped n it works fine now, i got new switch on n working so thats all done. i couldn't find a cover for my starter belt so i made one, im gana try n put pic on to show anyone who wants to make one i can make more if someone needs one too. i also hooked up led lights. i made a mf snow plow fit on the horse and it worked awesome this last snow we got. i know i need to adjust carborator im getting a bad smell of gas in my oil, am i correct in it being the carb or is it something else? i dont want to blow the k301 in it. Sorry i took pic before i put the top hanger on to the starter bolt hanging out. I tried to put pics of lights on but it wont let me. 1 Share this post Link to post Share on other sites
oldlineman 1,487 #2 Posted February 14, 2017 Could be the diaphragm on your fuel pump is leaking and letting fuel into the crank case. 1 Share this post Link to post Share on other sites
Kavint76 56 #4 Posted February 14, 2017 The exhaust smells of gas to would a fuel shutoff help if its the pump?where can i get a diaphragm for the pump?is it normal to have a gas smell in the oil? Share this post Link to post Share on other sites
oldlineman 1,487 #5 Posted February 14, 2017 Cheaper to get a new plastic pump, I have and they work ok, you should check out the pump first and see if it is the problem its just one thing that could cause this, a carb inlet valve not sealing correctly I believe could also cause raw gas to enter the combustion chamber and leak past the piston rings while not running. Share this post Link to post Share on other sites
Kavint76 56 #6 Posted February 15, 2017 Thnx everyone with the advice i adjusted the carb it was running to rich. That seemed to work no more gas smell out the exhaust or in the oil i ran it 4 an hr or so after adjustment. Ill check the oil again after a few more hrs to double check. 1 Share this post Link to post Share on other sites
Retired Wrencher 5,546 #7 Posted February 15, 2017 Kavint76 Nice job on the belt guard. There on e/bay every once in while. Keep up the good work she will pay you back. Share this post Link to post Share on other sites
Kavint76 56 #8 Posted February 15, 2017 Thnx i love my old horse she still a hard worker 1 Share this post Link to post Share on other sites
CharlieC 0 #9 Posted February 15, 2017 You should add one of those small gas shut off valves, I have a small sears mower that during the winter all the gas drained thru the carb and filled the crank, over a gallon of gas was in there. Share this post Link to post Share on other sites
