Justy37 41 #1 Posted February 13, 2017 (edited) Hello, I am hoping another member here with a 953/1054, has some pictures or can show how the cable that lifts the hitch is routed. My 953 does not have the cable, nor the pipe above the axle that guides it. From looks of it, at one time it did have one. But they replaced the cable with a piece of chain bolted to the axle, which holds up the hitch. Thought being the 953 is capable for a somewhat hydraulic hitch lift. I could get that working for a moldboard one bottom plow. Edited February 13, 2017 by Justy37 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,052 #2 Posted February 13, 2017 I have a 953 at home I can get pictures of after work. Share this post Link to post Share on other sites
Justy37 41 #3 Posted February 13, 2017 Awesome, Thanks Mike! Share this post Link to post Share on other sites
953 nut 56,670 #4 Posted February 14, 2017 You can get the cable assembly complete with conduit and end yokes from @wheelhorseman1000, he is a vendor here and his cables are first class items. I have bought a couple of them. 1 Share this post Link to post Share on other sites
Justy37 41 #5 Posted February 14, 2017 Thanks 953 nut! 1 Share this post Link to post Share on other sites
wheelhorseman 3,211 #6 Posted February 14, 2017 15 hours ago, 953 nut said: You can get the cable assembly complete with conduit and end yokes from @wheelhorseman1000, he is a vendor here and his cables are first class items. I have bought a couple of them. Thanks for the compliment 953 nut! Here is a link to the cable: http://www.wheelhorseman1000.com/product-p/repro-lift-cable-2814.htm 1 Share this post Link to post Share on other sites
Justy37 41 #7 Posted February 14, 2017 That's good parts are available. Still need to figure out how cable is routed and connected to rocker shaft. Share this post Link to post Share on other sites
Justy37 41 #8 Posted February 15, 2017 (edited) Well I got it done. Fired up the lathe and made a tube out of solid rebar round stock. Made a cable with my cable air crimper. Tomorrow will fab up a another hitch to replace the slot hitch. Will make the identical step with a 2.5" receiver. Edited February 15, 2017 by Justy37 2 Share this post Link to post Share on other sites
TravelinJavelin 620 #9 Posted February 15, 2017 can we get pics please? Share this post Link to post Share on other sites
953 nut 56,670 #10 Posted February 15, 2017 23 hours ago, Justy37 said: need to figure out how cable is routed and connected to rocker shaft. This is not a 953 transmission, but for the purpose of this question it will get the job done. The conduit that the cable runs through from the rocker shaft to the slot hitch has a clamp that attaches to the top of the transmission and is bolted to one of the threaded holes on the top. Share this post Link to post Share on other sites
