Throttle Linkage Adjustment K181
By
Joebag, in Engines
Similar Content
By Goldnboy
I am attempting to convert a K321 from a Ford/Deere style throttle-governor to wheelhorse style. The hole shown is where the bolt attaches the bellcrank that the governor spring and throttle rod connect. The Hole on this block is there but was not tapped out to screw in a 1/4" bolt, also about half way in is some hard as #$$@ metal insert that has ate 4 drill bits. How do I get this tapped?
By Dan693
Thinking about trying a foot pedal throttle on my WH,
Has anyone ever tried it and how did it work out?
Thanks!
By DownHome
I've noticed that while driving any sort of elevation change, whether it's up a hill or down I start losing throttle. What type of fuel delivery issues could I be having? Occasionally it will even die out almost completely. Sometime if I mess with the throttle I can get it back on track but seems like i shouldn't have to fuss with it that much? Any thoughts? Thanks in advance
