ohiofarmer 3,470 #1 Posted February 13, 2017 I have a sunstrand 90-2014 on a 1075 [a roller] with 1 inch axles and a Sunstrand 90-2046 on an Electro 12 with 1-1/4 axles Beside the obvious differences of the location and appearance of the neutral disconnect, what parts are the same and which are different? Also, I am looking at a C-160 and am wondering if the 90-2046 will fit it? Thanks for your interest. Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted February 13, 2017 Did you mean "a Sunstrand 90-2046 on an Electro 12 with 1-1/4 axles " or 1-1/8"? Share this post Link to post Share on other sites
ohiofarmer 3,470 #3 Posted February 13, 2017 1-1/8 Sorry Share this post Link to post Share on other sites
953 nut 68,588 #4 Posted February 13, 2017 Seems that most Sundstrand transaxles can be attached to similar year frames, the motion control levers may need alteration and a bit of sheet metal could need massaging, but that is all part of any swap. I see no reason to doubt that it would be doable, just a matter of putting the two side by side and seeing what will fit and what needs alteration to fit. 2 Share this post Link to post Share on other sites
ohiofarmer 3,470 #5 Posted February 14, 2017 (edited) Well, one thing that is a difference is the drive pulley. the 1075 has the small pulley and [i assume] the metal fan that goes with it There was a bit of aluminum center still there but no blades at all. I had to buy a long 3/8 drive Allen to get the big pulley off. then i had to make a special seal puller to get the seals off . used a 5/16 Allen wrench and ground the paint lid puller profile and it worked a treat. Made a tool thread about it. Sorry for the shaky picture The 1075 roller is strapped to a 2 wheel cart just to make it take up very little space and easy to move around. That cart will stand up with the 1075 mounted no problem,My worker is beside it for comparison Now to order some seals and get these two transmissions in order Edited February 14, 2017 by ohiofarmer Share this post Link to post Share on other sites
pfrederi 21,074 #6 Posted February 14, 2017 The 2 different input pulleys are because older tractors use small (2" +/-) engine pulleys. the Charger Electro Raider tractors had 4 " (+/-) engine pulleys. 2 Share this post Link to post Share on other sites
ohiofarmer 3,470 #7 Posted February 18, 2017 Spoiler Finding seals Since the cross check part number chart on Redsquare is mostly for manuals, I thought that i would share another way to look up oil seals. I first removed the seals to measure them and even that is not an exact science as they have some runout from removing them. There is a British website called SimplyBearings.co.uk Here is a screen shot. http://simplybearings.co.uk/shop/Seals-SKF+Seals/c19_4749/p305253/SKF+CR11124+Double+Lip+Nitrile+Rotary+Shaft+Seal+1.125x1.624x0.25+inch/product_info.html They have a place to enter the seal measurements and it gives metric to SAE conversions and it will even offer suggestions even if you entered slightly the wrong size. However, the stuff I wanted [SKF double lip seals] was not in stock and I have no desire to phone them for assistance. I entered the SKF number in NAPA online and found a NAPA corresponding part with the same number but a different prefix NOS instead of CR. Even those are special order from NAPA, so it might get pricey Here are the SKS vs. NAPA parts for the two tractors" Shaft seal for the 1" axle auto trans Wheelhorse 1055 [ SKF] CR9863 [ NAPA] NOS 9863 Shaft seal for 1-1/8 axle auto trans Wheelhorse Electro12 [SKF] CR11124 [ Napa] NOS 11124 Input shaft for both pump inputs with 3/4" shaft [SKF] CR 7475 [NAPA] NOS 7475 i hope that this is correct. It could get expensive if I am wrong. 1 Share this post Link to post Share on other sites
pfrederi 21,074 #8 Posted February 18, 2017 CR 11124 is correct replacement for WH#6449 (1-1/8") axle 7475 is also correct for pump input shaft 7474 will also work but is only a single lip seal I prefer the double lip 7475 CR9878 is correct replacement for WH 5958 (newer # 100607) You 9863 may work it is very close. The SKF interchange is a quick easy way to find most WH seal #s http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm Share this post Link to post Share on other sites
