1995 520H+96+97
Seat Time Again
1995 520H+96+97
3/24/2018. Change over, 1997 520H. 46 degrees. 105 hrs.  :wh:
5ab69b7da54d2_3-24-2018009.JPG.8f9eb036d461de0614982374f52117b7.JPG5ab69bbabba6f_3-24-2018008.JPG.1c3ed842243b55cabe0a72ac3eb07f9b.JPG
5ab69a828c5e2_3-24-2018001.JPG.08f33fe66022879e4860f4248ccb65c0.JPG5ab69abc6575b_3-24-2018003.JPG.f3259ac28583a11a4e211c73fcd994f3.JPG
Edited by 1995 520H+96+97
  • Like 3
  • Excellent 3
WVHillbilly520H
Man that '97 sure is sweet :clap:.
  • Like 3
1995 520H+96+97
      Sweet Spare.  :wh:
1995 520H+96+97
Started snowing.  :wh:
1995 520H+96+97
4-13-2018. Change over 1995 520H.  1145 hrs. :wh:
  • Like 4
1995 520H+96+97
4/18/2018. 35 degrees, :wh:
11:00 AM. 42 degrees. another load.    :wh:
  • Like 4
1995 520H+96+97
4/18/2018. 44 degrees, third load firewood.  :wh:
Ed Kennell
Man that makes a lot of sawdust when you saw the chunks.    If you were closer, i'd  bring this.
  • Thanks 1
1995 520H+96+97
4/19/2018. 42 degrees. 1st load. :wh:
2nd load firewood. 49 degrees.:wh:
1995 520H+96+97
4/21/2018. 40 degrees, breezy. 1st load. :wh:
Ed Kennell
Looks like each load gets stacked a little higher. :scared-yipes:
1995 520H+96+97
 Ground is drying, load em heavy. :wh:
4/21/2018. 48 degrees, breezy. 2nd load. :wh:
1995 520H+96+97
4/22/2018. 3 PM, 60 degrees, breezy. Snow should be gone this week. :wh:
1995 520H+96+97
5/6/2018. First mow of 2018. 1 3/4 gallon gas. Start hrs. 1149.5, ending hrs. 1150.5. :wh:
1995 520H+96+97
5/16/2018. 33 degrees 6 AM, 42 at 9 AM. Couple of trees leaning towards road, power lines, 520H to light to pull. Ferguson TE-20 did the job. :wh:
  • Excellent 1
1995 520H+96+97
5/16/2018. 11:20 AM ,57 degrees. Cut, loaded, another leaner. :wh:
peter lena
where I live in Connecticut, ever source handles power, and do a terrible job at it, glairing tree and maintenance issues are ignored .talking to line repair people , they fear termination over job/work ideas. crushing management mentality. you are smart to keep after area, good luck , pete
1995 520H+96+97
6/16/2018. 7:50 AM,58 degrees, 1 gallon gas, 1159.6 hrs now. Been mowing once a week.
1995 520H+96+97
6/23/2018. 7:45 AM, 58 degrees. shared mowing duty 1995 with the 1997 520H. 1 1/4 gallon gas.
lynnmor
A couple of comments.  I would think that the bungee cord is rather hard on the plastic bushings in PTO lever.  I have been keeping the deck belt covers on for the past 18 years, my left foot is still numb from the serious damage.  I see you added a wear surface on the upright piece on the deck, I added nylon pieces there as well and they are holding up after many years, steel on steel wears rapidly.  Do you have a source for the caps on the front spindles?
  • Thanks 1
1995 520H+96+97
10/13/2018. 3:30 PM, 47 degrees.  Change over the 1995 Toro 520H. 1181 HRS now.
Mowed every Saturday, 1 gallon of gas every mow, belts look OK, bearings quiet.
Sharpened blades. 1 quart motor oil for the summer season, 31 hrs.:wh:
  • Excellent 1
1995 520H+96+97
10/14/2018. 12:30 PM, 51 Degrees, Breezy. Mowed and change over, 1997 Toro 520H. 108.3 HRS now. 3/4 gallon gas.
  • Excellent 1
1995 520H+96+97
12:15 PM to 1:00 PM snowblow 4" heavy snow with 1996 520H  768 hrs. 1/2 gallon gas, 85 degrees in cab.
Still snowing, suppose to change over to rain.  :wh:  :)
1995 520H+96+97
6:15 AM to 7:45 Am.19 degrees, slight breeze.
Snowblow 5" dry, fine snow with 1996 520H and scrape with 1995 520H.
1 gallon gas, 86 degrees in cab. :wh: :)
Daron1965
I really like your set up.  You have the best of both needs covered.
  • Excellent 1
