proshop
12 horse kohler
proshop
Gas is flowing out of my carb when it's warmed up and shuts down the engine. :whistle:
is it a stuck float? :thumbs:
I vated the carb last month and was running great untill yesterday. :whistle:
Is there a quick fix
Thanks
illinilefttackle
Do you have a inline gas filter in your setup? Sounds like a piece of dirt in the needle & seat valve. But, just in case the float is hung up, try tapping on the carb body to beak it loose.---If not, then take bowl off and clean out the needle and seat. Good Luck!-AL
proshop
I've rebuilt this B-100 Auto from ground up including the engine and did not think to put an in line filter. there might be some crud in the gas tank that is cloging the carb.
I'll give it a filter and check the bowl out to see.
It is a dangerous place to leak cause the hot mufler is right inline below the carb,and leaks on to it.
Thanks :thumbs:
Tim
