eibbed
4 HP KOHLER
eibbed
Gentlemen,
Does the 4 HP Kohler use a pull rope to start or does it have a recoil?
Also, does it have a shaft smaller than 1"diameter?
I located two of them yesterday, pull rope start, painted red and I think 4 HP. Thought maybe they were used on earlier Wheelhorse models.
What do you think? :thumbs:
Thanks,
Dave
TT
The K-90/K-91 Kohler engines could have retractable (recoil) start, rope start, or even electric start. (starter/generator)
I have seen at least four types of recoil starters used on these, including Schnacke, Fairbanks - Morse, and two versions of Kohler's own stamped steel unit.
Some were battery ignition, but most seemed to have magneto ignition.
I believe the "standard" crankshaft diameter was 3/4".
It's probably easier if you post pictures. :thumbs:
linen beige
I'll add that some even had 110 volt starter motors that plugged into the wall. Kinda useless if the engine died in the field! :thumbs: (I know they were meant for stationary apps.).
Check the model number tag closely before you try one on a Wheel Horse. Some had gear reduction units. The cranks on these weren't long enough to mount drive pulleys to. The gear reduction models were K-91 RT, RS, etc.
Like TT said, pics would help.
eibbed
Thanks guys,
I'm going back down to his place in a couple of weeks and will get pictures and numbers then.
Dave
