alan freiheit
what did I do wrong
alan freiheit
I recently bought a 1974 C161 with snow plow. The first chance I had to use the plow it worked great until I had an electrical fire. Insulation on wires to the light switch and ignition switch burned. I can replace the wires and might need to replace the switches but I am wondering why it happened. Here are the conditions.
1. I was plowing at night which should not be problem
2. I had a hard time getting it started and tried jump starting from my truck. Could that have burned out a voltage regulator or something?
3. The area behind the dash board was found clean of grass clippings etc.
4. Just before the fire, the light went out and I think the wires to the light switch were the fire origin.
oldandred
Sounds like to me that you had two wires rubbing together and was no fuse or it just happened to be a none fused wire.
replace the burnt wires with the correct size ans make sure every thing is sealed or taped with no bare wires.
jumping want burn out a reg, if its done right
Rewire and hope for the best
