AMC RULES
2 hours ago, DennisThornton said:
I'm thinking Craig was not meaning wheel weights but rather referring to weight hanging OFF the back.  Behind the rear axles.  To counter balance that blower hanging OFF the front.  My 522xi came with a weight box on a heavy duty bracket that is well behind it's axle.  And it has power steering.
You got it Dennis.   :greetings-clapyellow:
shallowwatersailor
My suggestion is the Vredestein V61 in four-ply 16x6.50-8 size. I know that it is slightly narrower but other members like them as well. I'm sure someone will offer a photo installed.
BaySide1
On 2/1/2017 at 11:53 AM, bmsgaffer said:
You didnt mention asking price, but if the restore is as good as it looks in those pictures (which I would expect since they have pics of the restoration) I would expect that to run in the 2500 (super deal) - 4000 range and I wouldn't bat an eye if I was looking for one. Especially with the low-hour onan.
Tractor - 1800-2000
2 Stage - 500-800
Cab - 250-500
Plow blade with extensions - 250-300
Mower deck - 150-250
wheel weights - 75 (plastic) - 200+ (cast Iron)
+ all the extra kibble and bits
That tractor looks familiar, it might be a members here?
Oh, and it appears to have been converted to the forward swept axle, so there is not much improvement on the 90+ models unless it does not have the gear-reduction steering.
The cab is pretty beat. the framing needs a lot of help and the vinyl is heavily faded and worn. The deck will need a little cleaning. Other than that everything else looks to be as described.
bmsgaffer
V61's on my old 520H
squonk
I'm putting tri-ribs on my 520 this spring. :banana-dance:
Ken B
Here's my take, Its an Onan with 550 hours on it.. That is good only if it was taken care of since day one. If it comes with a 60 inch deck then that means it was worked a little harder than if it came with a smaller deck. That Onan is working pretty hard if you are cutting thick high grass with a 60 inch deck. Onans no doubt require more maintenance than the Kohler engines and parts are a bit more expensive. I hope whoever was operating the tractor kept the blower screen clear from grass clippings because that Onan pulls alot of air and the screen clogs real fast, which can cause over heating.  I don't like to tally up the tractor and all the attachments separately to try to convince myself I'm getting a good deal. Package deals are cheaper. Its a real sweet tractor and its owner did a real nice job on it but 2500 would be the absolute max I'd pay for it... I owned an 88 520 with 300 hours on it. It was an absolute beast in the snow and had no problem pushing near 2 ft of snow...
Edited by Ken B
  • Like 3
shallowwatersailor
I bought a used cab this past Fall that needed some replacement frame parts and the vinyl front. When I called OTC for replacements, the frame pieces were reasonable priced. Probably  because above the attachment points, they are pretty much alike. But the vinyl piece price quoted was absurd as it fit only my 5xi!  I balked at the price and the lady on the phone did some quick figuring. I was then offered a lower price ( abit more than half but still was $135.00) which I agreed to. Now I had been a previous customer so that may be a factor but you might be able to negotiate.
If I was setting a price on all used cabs I would say $500.00 for an intact cab that didn't need any work. Less so that with replacement parts so it can equal $500.00. The current price on a new 5xi cab is $959.00!
BaySide1
On 2/1/2017 at 5:27 PM, KC9KAS said:
@BaySide1 :text-welcomeconfetti: to :rs:
Keep us informed of your "pending" Wheel Horse purchase!
Done Deal !!
Cee245
Nice! It's a lot of money, but with all you are getting, I think it's a very good deal!
KC9KAS
12 hours ago, BaySide1 said:
Done Deal !!
:woohoo:
BaySide1
Can anyone help me figure out what year this is? I believe it has been dressed with the wrong stickers.
  • Like 4
BaySide1
one has a parking brake release lever on the left side.
The Black lever is also missing. Where do I find one?
Sarge
After the fact ...but here's my take on values of so-called "restored"...
Unless you where there or they documented everything , including machine work and a list of new parts - never let the shiny object push you to pay a lot of money , that can be a huge mistake . Shiny and new looking means just that , and nothing more in the mechanical sense . I see a lot of "restored" machines for sale that are flat worn out and would cost double their asking price to fix properly . Worn out bearings and associated issues with front axles/spindles , steering components , bushings and such add up really quickly and some of those parts aren't available for many models so hunting good used parts becomes expensive in it's own right . I see a lot of really nice paint jobs with a bad hydro transmission , rare missing parts , engines that are worn out and have their own set of problems , ect...that's not a nice feeling for someone who just dumped a lot of cash into a machine , only to take it apart to fix it and possibly damage that nice attractive paint/stickers . There are a few people out there that will only "do it right" and will occasionally sell a machine after it's done - we know who they are and they even offer them up at more than fair prices - so buyer beware .
Shiny objects cost a lot of money and often come with an additional hidden price tag - keep that in mind when shopping .
Sarge
Kurt-NEPA
Definitely the wrong decals - they are from an 1988 or 1989. Your 520H is somewhere between 1990 and 1997.  The only significant difference over those years is the addition of gear reduction steering in 1992 or 1993 (I think).
What is your serial number?  That will give the year.
You are really going to like that two-stage.  It is beast.  There are several things you can do to upgrade it that really help.  As was said earlier, hang about 140 lbs off the rear and steering will be much improved.
BaySide1
where do I find the serial number?
Found the decal on the engine
Kurt-NEPA
Under the seat - left side.  Probably under the cab bracket.  Should be a tag with model and serial number there, unless it got removed during its restoration.
BaySide1
any other places?
is it stamped anywhere?
Thanks
bmsgaffer
If redone the sticker is probably missing. The engine tag can get us close +/- a year or so.
BaySide1
Looks like the engine was manufactured in January of 1991 in Huntsville.
So, the tractor is a couple years newer than I thought. Was thinking 1988/1989 due to stickers on hood.
then, I noticed the parking brake set lever which puts it at 1990 or newer.
bmsgaffer
If the engine is a '91, there is a very good chance that your tractor is a 92 (a small chance puts it late in 91 also). This means that it will have the gear reduction steering as well. An excellent tractor, I loved the '94 I had.
Edited by bmsgaffer
BaySide1
What do I look for to see if it has gear reduction steering?
Edited by BaySide1
bmsgaffer
How difficult is it to steer with that 2 stage on it? If you can do it without too much effort (If you haven't said to yourself 'wow this is kinda tough'), then you most likely have gear reduction steering. :handgestures-thumbupright:
BaySide1
This rigs steers a whole lot easier if you lift the blower. Drop the blower and all bets are off. Maybe need chains on the front tires or weights.
Kurt-NEPA
To look for gears reduction steering, Take a look under the tractor a the base of steering column.  If it has gear reduction you will see a gear box there.  Part no. 19 in the diagram with the gears attached.  If not gear reduction, then the steering will just engage the fan gear.
Red144runner
On 2/1/2017 at 11:42 AM, BaySide1 said:
Looking at several Wheel Horse Tractors
Found a Late 80's fully restored (new powder Coat Paint and decals) 2 stage snow blower, plow blade, mower deck, chains, wheel weights, hitch weights, extra chute for blower, extra belt, LED lights and a Wheel House Vinyl Cab with an LED light bar.
Owner states work done three years ago and 20Hp Onan Motor has only 550 hours.
What would be the Top Price you guys would pay for this?
I think his price is a bit high but then again, everything is good to go and it is really sweet looking.
Are the 1990 forward models any better?
This thing is in Show Condition!!
Thanks For your input
Kevin
I've seen that one local on cl. Looks great too rich for my blood thought
Kevin
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
