Sourcing a suitable PTO Electric Clutch for a D200
By
stevieb, in Wheel Horse Tractors
Similar Content
By BuffaloD200
'74 D-180
My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
So my thoughts are grab a BFH or sparky the blue tip wrench.
Is there an unpublished step 3.5, or some trick?
By BuffaloD200
Hey all, I need to install a drive belt on my 75 D180 for my snowblower. I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure. The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell. Do I have to remove the PTO pulley? That seems to be a required service item.
Same question for my 80 D200 as well really.
Using the recommended 4L490W belt.
Thanks
By BuffaloD200
Hey all, I'm doing my first fluid change on my new-to-me D200. Refilling the transmission is proving to be quite the struggle. I've attempted to fill the tranny through the dipstick with a variety of funnels, but the oil just spills over the top. I may have managed to get a quart in.
What am I missing?
By cbj75
I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
Package price $3000.00.
Bryce Johnson
102 Anglers PT
Mc Cormick SC 29835
913-638-6788
IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
By the jeep driver
My daughter was using the Wheel Horse rider to mow, I was push mowing. She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving. I disengage the blades, and re-engage... nothing. No movement from the belt nor clutch. Then I notice the smell, and look closer, the belt is so hot is melting on the clutch. Or rather, the clutch is so hot it's melting the belt. Melting occurred.
While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
So, what did I do now? Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall. I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad. I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
Some pictures of the clutch, can anyone tell if it's usable from them?
