meby
Added weights to my D 160
meby
Finally got my weights on the tractor. I've had them sitting around since last spring and we turned them down to fit earlier this winter. Cast iron in a lathe makes such a mess! The mounting holes were right, but the diameter was to big. Originally they weighed 62 lbs each. We wound up at 46 lbs x4 for 184 lbs total. I also put chains on it to plow with... what a difference.
Later this year I'd like to get some Carlisle Tru powers on it and load the tires.
  • Like 4
KC9KAS
@meby  I bet that weight really helps!
Am I looking at 2 weights on this rear wheel?
Nice that they don't stick out to far.
meby
Two weights per side. yeh, not a fan of weights sticking past the wheel.
slim67
weight is good !! makes all the difference.
