![Leelee](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Similar Content
By jebeli
So I have an old and tired K161 with an electric start. I picked up a K181 at the show but is a pull start. I swapped the flywheels and the cowling wont fit over the plate behind the flywheel. And the recoil tin has a smaller hole compared to the electric start. So if I swap the plates behind the flywheel does the crank shaft bearing come of to? Do I have to press this back in? Maybe I should just find a k181 elec start tin?
By tntatro
The stator and flywheel on this engine are different than others I have worked on so far. The stator is smaller in diameter and has a wire that runs out to a part that looks like an ignition coil but has no plug wire. I am wondering what it is and how do I wire it?
I'm not 100% positive that I put it back in the same spot it came but I think I did. I gapped it at .020" from the bump that sticks out on the flywheel, it is magnetized.
By Bear G
Anyone know how the Steering Wheel comes off a D-160?
I don’t see any set screw, bolt, or roll pin.
Are these pressed on?
By Lablan
On a 1992-1996 520H wheel horse lawn tractor, I have replaced the starter motor and flywheel. I also replaced the coil, condenser, plugs and wires. After all that was done, the tractor started first time cranked and I mowed the 1 acre yard one time. When I went back to mow again it would not start and I see the starter motor is now chewing up the flywheel gears. The new flywheel now has severe burring on the engine side. It looks like the starter is not fully engaging into the flywheel. The mounting bolts have a thick washer. Are those washers supposed to be spacers between the engine and the starter motor, thus moving the nose of the starter closer in toward the flywheel? Am I doing something else wrong?
By Sea-Duck51
I was looking for a small tractor with FEL and came across this honey hole,only interested in the D-160 but offered to buy them all to help out the owners son,father is not well,only thing I know is the D-160 (350 hrs on tractor)was re-powered a year ago with Wisconsin engine,no specs on that,supposedly they all run,414-8 has a belly mower so gents judging by the pics what's a decent price for all three tractors.
D-160 W/FEL
416-8
414-8
